Question about Whirlpool Dryers
I have a Whirlpool dryer model # LGR5620KQ which is not drying/no heat. The clothes tumble, but not dryijng. The vents are clean and clear.
  • 725 Answers
You either have an element out or your t-stats are out. You have a thermal fuse also that could go out. On most dryers, if the t-stat goes out, you should replace all the t-stats and thermal fuse. Pull the element out first and if there are no visible breaks or burn marks on the coils, it's not the element. Call or email us and we will be sure to get the proper parts right out to you asap.
Hope this works for you.
Posted on Sep 30, 2009
Gas dryer will heat but won't dry clothing
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, and recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance.
Oct 23, 2015 | Dryers
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
My Whirlpool dryer tumbles but no heat. The clothes dry after along period of time and that is when i finally feel some heat.
Probably needs a good cleaning. If it was me I would remove the filter housing and do a through cleanup. make sure the vent going outside is not blocked. The dryer must have adequate airflow to work well.
BEFORE AND AFTER
Oct 03, 2012 | Whirlpool Dryers
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Whirlpool cabrio electric dryer heats and tumbles, but clothes don't get dry
remove your duct from the dryer. DRY a few loads,IF the unit works fine with the duct off, You will need to get the vent to the outside cleaned
Feb 23, 2009 | Dryers
Whirlpool dryer tumbles but does not dry
the act that there is even a partial heating, bfore i say there may be a problem with the unit, I would ask that you check your venting for possible clogs/blockages. I fhte machine cant vent away the heat the it will not produce more. This is hte MOST common issue with all my dryer repairs. 2x-3x to dry clothes, start with the venting
Dec 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
I have a Whirlpool Model LGR5620KQ Heat Problem ....
Here's a site that shows exploded view parts diagrams for your model, which can be useful when working on it. --> http://www.partselect.com/MultiModels.aspx?ModelNum=LGR5620KQ&searchTerm=&RefineSearch=0 A dryer needs two things, heat & airflow. If you have the heat, look for a kinked vent hose or a blocked vent louver where it blows outside the house. If that doesn't help, write more and we'll keep trying.
Aug 10, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
