Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishwasher has not been used for 1.5 years. it is not draining and leaking out onto the floor.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ncb.mn
Posted on Sep 29, 2010
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
For no apparent reason that I can seem to find, the dishwasher periodically has the bottom full of water. It is not that a cycle was interrupted. It happens between uses. It is clean water and does not...
You seem to have a leaking inlet solenoid valve. It could be a bit of dirt stuck across the seats but it could also be the valve seats that have cracked or worn. Check the valve and replace it if necessary. It is the first component after the inlet pipe.
Feb 06, 2011 | Whirlpool Dishwashers
Intermittent leaking during wash cycle
is the dishwasher leaning foward,are you useing to much soap?start the dw with out anything in it let it run a few minutes open the door and see if there are suds in it if so way to much detergant
May 31, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
My dishwasher was pouring out suds onto our floor, why?
useing to much dw soap can cause it to fill it then drain it and again and again till its all gone
May 31, 2010 | GE Nautilus 24" Built-in Dishwasher
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
Dishwasher is not draining the water completely and is leaking onto the floor
Leaking Dishwasher
heatman101
sasgfgdf
Nov 15, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
My dishwasher won't drain, and leaked out onto my hardwood floor!
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Jun 23, 2009 | Kenmore Dishwashers
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
87 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
