Question about Lisle Serpentine Belt Tool
How do I by pass aircompressor
Need to by pass air compressor for a 2000 Astro Van. Serpentine belt router. thanks N Compressor went out and I want to by pass the aircompressor with a serpentine belt. Need a diagram on how that works. Thanks N.
Why bother, just pull the clutch coil plug and move on. When you sell it the next folks may want A/C .I would leave it.
Posted on Sep 30, 2009
I'm having trouble replacing my belt on my 94 gmc 1500 the air compressor went out now I need to find out what belt I need to by pass it
Is the belt a V-Belt?
If so- then you have bolts you can loosen to
move the compressor or other accessories
If it is a single serpentine belt, I don't see the problem
If the compressor hub or pulley still turns, you leave the
compressor there & just have no a/c
The truck is too old to be spending money with bypass
kits & such, for no reason.
If the clutch hub has a locked up bearing, replace it, if the a/c
would still work?
Jul 16, 2014 | Cars & Trucks
I need a Diagram on the Serpentine belt for an 2002 Eclipse. I need to know how to bypass the AC compressor.
The compressor cannot be by-passed, but you can disconnect the compressor clutch by disconnecting the two wire connector at the compressor; then the compressor pulley is just an idler.
Jul 30, 2011 | 2000 Mitsubishi Eclipse
My compressor is bad and i was wanting to bypass the compressor with a smaller belt, what size belt do i need to get
There's probably no way to find a serpentine belt to by-pass the A/C compressor. However, the compressor only spins when the compressor clutch is engaged, and if you unplug the clutch the compressor pulley spins freely on its bearing without turning the compressor. The clutch wiring connector is usually on the compressor near the pulley.
Jun 18, 2011 | 2000 Pontiac Sunfire
I need to get a diagram for the routing of a serpentine belt that bypasses the ac compressor.
There is not one,but napa auto parts sells a by pass pulley to replace the ac compressor and you use your same belt,it cost about 39.00 around here.If this was at all helpful,please rate thank you.
Aug 16, 2010 | 2000 Jeep Cherokee
CAN THE SERPENTINE BELT BE REROUTED TO BYPASS THE A/C COMPRESSOR?
No. The bearing on the compressor can be replaced without buying an entire compressor.
Jul 27, 2010 | 2000 Oldsmobile Silhouette
2000 Chevy Cavalier making a noise when air is shut off
This problem sounds like the aircompressor pully, the bearing is shot.
With the engine running and the air conditioner off there is a grinding noise, look at the compressor pully, does it wobble? Then turn on the air conditioner and the noise stops, look at the compressor pully again, the wobble stops? If so that's the problem.
Jun 27, 2010 | 1996 Chevrolet Cavalier
If available, see if you can get a belt for an Astro that is not A/C equiped. The parts store should have the routing diagram. Good Luck, Ned
Sep 30, 2009 | Heating & Cooling
By-passing the a/c compressor with a shorter belt
The best way to do this is first ask the parts house to see if this car came with out air and get a belt that way. I dont think that year had the option of not havnig A/C. The other way is take a piece of rope and put it around the pullys just like you are puttin on the belt but by pass the A/C you might have to make a few trips or get a few different size belts but its the only way
Jan 24, 2009 | 2002 Buick LeSabre
Serpentine Belt for 1988 Astro Van
1988 astro 4.3l with ac, no air pump takes a belt number k060947 which is a 6 rib belt 95 1/4". please rate
Dec 02, 2008 | 1988 Chevrolet Astro Cargo
Lisle Serpentine Belt Tool Logo
112 people viewed this question
Top Lisle Hammering Experts
john h
steve morris
steve morris
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
