Question about CTX Optoma EzPro 580 Multimedia Projector
No picture When I turn my computer on, the Window screen is displayed through my projector, but then it goes to white. It will not display my computer screen.
    Problem Solver:
  • 12 Answers
You may need to reduce the resolution on your comptuer screen. Try going to Control Panel, Display, and Settings and lowering the resolution a notch or two.
Also, you must make sure that the computer is set to send the signal to the external monitor,. That usually means holding down the Function key and pressing the F5 key or the one with the picture of two monitors on it. You will see several options for display. Toggle with the F5 key to the one that shows the computer screen and the external monitor at the same time.
Posted on Mar 24, 2008
Can hear sound but cannot see picture
Hi, if your LCD projector turns on and projects light with sound but not the picture on your computer screen, first make sure the projector is plugged into your computer. If it is, check your computer display settings. Go to "Control Panel" and "Settings" or "Windows Setup." Select "Display." Make sure it's set to appear on your laptop screen and the the projector screen. Most laptops have a "Fn" key dedicated to changing the output display setting.
If your projector turns on but emits no light or picture, replace the projector's bulb, often called the lamp. Most have a life of between 2,000 and 6,000 hours. Your projector may warn you when the lamp life is about to expire, although some models simply stop working when the lamp needs replacing.
Thank you.
Jun 06, 2012 | InFocus Proxima UltraLight DX3 Multimedia...
We have a Toshiba TPB P5 projector that displays all menus, and shows the computer display fine at first, but as soon as the video changes (new page, new window) the projector shuts off and goes to...
First check your video with ANOTHER external monitor. It may be the video output of the computer turns off (It often comes from a different driver than the main computer screen). This would then be a software problem...
Jan 09, 2010 | Toshiba TDP P5 Multimedia Projector
LCD projector not displaying color only black and white
Did you ever see color on this projector?
It could be the composite input cant detect the "color burst" 3.58 mhz signal for chroma.
Have you tried a different input?
That could help you track down what the problem may be.
Oct 31, 2009 | Televison & Video
Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
May 12, 2009 | CTX Optoma EzPro 610 Multimedia Projector
Differing size display when using Dell 3200mp LCD projector
Once your display of the projector is set( all connection to computers via cables is done), then all the display settings remain with the source i.e. the laptop.
You will need to set all your laptops to the correct display properties. This you can do by either going to presentation mode or on Window XP you can simply go on to your desktop and right click > go to properties>go to setting> press display 2 and set the screen resolution as per your projectors resolution and enjoy. ( for information: display1 is the resolution meant for your laptop)
Please do rate this solution and Thanks for usinf FixYa!
Mar 09, 2009 | Dell 3200MP Multimedia Projector
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
CTX Optoma EzPro 580 Multimedia Projector Logo
133 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
