Cut-Off Saws & Grinders
Problem for Cut-Off Saws & Grinders
Generic problem for all Cut-Off Saws & Grinders
Makita concrete gas saw 14
By kenwbryant on Sep 30, 2009
Makita concrete gas saw 14" has spark compression and fuel but wont even burb. replaced 140.00 coil but did nothing. anyone have this problem?
Clarification Request
Posted by vincob on Sep 30, 2009
Make sure you have correct plug and gap set correctly and if you are mixing gas and oil make sure of correct ratio. If there is a safety break bar like a chain saw make sure it is disengaged. Also check to see that the fuel line is not clogged or pinched and if you have a fuel filter check it also. If you moved any needle valves you might be out of adjustment but that is only if you moved them, if you did not do not touch them at this point. Good luck!
Popular Solutions for Cut-Off Saws & Grinders
Questions and Unsolved Problems for Cut-Off Saws & Grinders
Answer
which up cut saw should I buy
Answer
My scrollsaw is losing tension. The blades are tight, but it is still losing tenison.
Answer
How do I change the pull start cord on a 2 stroke husqvana partner 750 cut off saw
Answer
is it normal for 14" abrasive chop saw blades to not last long. It seems to loose cutting... (More)
Answer
cam lever does not tighten sufficiently, slips sometimes if knocked with wood, thus making a bigger... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cut-Off Saws & Grinders :
Top Cut-Off Saw & Grinder Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Cut-Off Saw & Grinder Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
