Question about Linksys Wireless-G WRT54GS Router (e125894)
How do i get into a linksys router to change settings?
    President:
  • 2,187 Answers
If the router is still on its default while you have your computer connected to it, you need to go to the router set up page by typing http://192.168.1.1 on your browsed and username should be left blank while password is "admin". If the router has been changed already.. click start -> run -> type CMD. On the black screen type ipconfig. Look for the default gateway and type the 4 sets of numbers on your browser.
Posted on Sep 30, 2009
  • 496 Answers
Open up a web browser and enter in 192.168.1.1 in the address bar when the login screen appears leave the user name blank and the default password is admin. hope this helps
I am using 3g wireless router buyed from wifi digisol company. can anyone please help me to tell is this product is right for internet communication. for more details related to this product visit htt
Sir
Using 3g wireless Linksys Routers is best router you use for inter net connection,
For customers using the AT&T 3G MicroCell and a Linksys / Cisco router model WRT54G2 or equivalent, the following settings should be made to the router.
NOTE: Changing the broadband router / modem / gateway settings may cause other applications to stop working, and / or change the broadband router security settings for outbound data transmissions. Please see the router / modem / gateway instruction manual for more detailed information.
Procedure
1.Open Internet Explorer and navigate to the router setup page at http://192.168.1.1
2.Enter the User name and Password, click OK
3.Verify the following settings:
Automatic Configuration - DHCP
MTU: Auto
4.
Select the Security tab, verify IPSec Pass through is set to Enable
5.Click Save Settings
I Hope Your Router Linksys Routers Problem Is resolved By now:
In case you need online Linksys Routers help then follow us on for:
Linksys Router Support
Apr 02, 2014 | Linksys Computers & Internet
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
How do you change a channel or mode on a linksys router
login to the router page.., you would be able to make the necessary changes under the section wireless in a linksys router.
Mar 03, 2010 | Linksys Wireless-N WRT150N Router
How can I setup my Linksys 54g v2.2, with my ZyXel 660r modem from embarq so that I can use my laptop with the routers wifi?
First of all you need to set you modem router to bridge mode. go to this link will explaine in more detail
http://kb.earthlink.net/case.asp?articale=69205
remember to change the linksys router ip to 192.168.2.1 or 192.168.0.1 somthing different from the modem .
Hughes modems are all set to 192.168.0.1 so simply setting the linksys router to default 192.168.1.1
you need to change the linksys router IP to somthing different 192.168.0.1
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
