Question about T-Mobile Dash Smartphone
Speakerphone Only My Dash will only operate on Speakerphone. If I make a call, or receive a call, it will automatically be on speakerphone. When I hit Menu, it shows that Speakerphone is off, and changing this option will not turn off speakerphone. Also, I am not even able to Mute calls during a call. I've tried using 2 different earpieces and no sound will come through them; it still operates on speakerphone.
  • 8 more comments
  • krishnagw Dec 22, 2007
    I purchased a dash about 13months ago and on the last day of my warranty, the phone was stuck on speakerphone. Tmobile told me to reset the phone, and this worked for a day or two. Now, it won't go off speakerphone and Tmobile won't cover this under the warranty. Is there anything you know of to get the spkrphone off? I've tried resetting the phone many times...
    and moving the tab where it charges didn't work...
  • kbellies Sep 03, 2008
    Same as the problem stated....it always stays on speakerphone...I've synced it..nothing works!!!!
  • Anonymous Sep 18, 2008
    What exactly did you do to fix it?  I've read push on the tab that the charger touches but that still not fixing it.  Are you using the charger to push it?  I also read hook up the charger end and the USB end to the computer.  That's not working either.
  • wjustinleigh Oct 19, 2008
    I have the same problem, none of the solutions posted made a difference.
  • Anonymous Oct 29, 2008
    Same problem here too
  • Anonymous Nov 03, 2008
    can only hear using speaker phone. just got the phone in the mail today. :OS
  • Anonymous Dec 21, 2008
    I have the exact same problem. Also just over a year since I bought it.
  • Anonymous Mar 03, 2009
    same problem with mine... no one seems to have the solution... chuck the phone
  • Anonymous Mar 04, 2009
    I have the same problem. I've had the phone for two years, and the problem just started today.
  • youwentawaay Apr 07, 2009
    i have the same problem. the only way i can hear anything is if it's on speakerphone. i've had this phone for three months.
Heres The Answer, Use The Data Cable the Dash Came With And Hook It Up 2 The PC. That Should Fix this Issue Instantly
Posted on May 18, 2008
That happened to me and I went into the bottom of the phone where you charge and pushed the little tab upward very slightly and it fixed the problem. Not sure why or how but it did. I hope it fixes it for you too.
Posted on Dec 22, 2007
If you sync your phone with a PC using a usb cable it will come out of speakerphone until you power it off again.
Posted on Dec 05, 2008
How do i turn off the speaker on motorola razr v3c
The speakerphone remains on until you press the smart/speakerphone key again or turn off the phone. You will see Spkrphone Off.
You can also set your phone to turn off the
speakerphone automatically after 20 seconds of inactivity:
Press the center key > wSettings > Initial Setup> SpeakerPhone > 20 sec timeout
Also The handsfree speaker is disabled when you connect your phone to a handsfree car kit or headset accessory.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 27, 2010 | Motorola Mobility RAZR V3c Cellular Phone
I have i8910 , how do you operate the speakerphone. Is there a switch or button to allow the speakerphone to operate?
I checked the manual for your phone and there is no instructions to access the speakerphone function.
However, on most PPC's that function is not available until a call is in progress. Look for it while a call is in progress.
Mar 30, 2010 | Samsung OmniaHD i8910 Smartphone
Need instructions to program Living Solutions Speakerphone ATC-355
living solutions desktop phone (model unk) programing.
turn on with speakerphone button
hit store button once
enter phone #
hit memory button ( where number is to be stored) once
hit auto button once
to dial stored #'s
kift reciever or turn speakerphone on
hit auto once
hit memory button (where # is stores) once
wait for completion of call
Sep 19, 2009 | Lands Phones
How do I turn on the speakerphone? When I press
try lifting the receiver pressing the speaker button and then put the receiver down.
Jul 23, 2009 | GE 29385GE1 Corded Phone
Avaya 2410 speakerphone
hi
what you could do is duplicate the set-up of a working phone for the new phone and see if that works
to idle a phone use busy sta <extens> and release sta < ext>
May 22, 2009 | Avaya 4621SW
Speakerphone when answering blackberry pearl 8100
I have never a newer blackberry but on the ones, I had this worked for me. When you go into your profile to change them if you hit the menu button while you one of the profiles highlighted there should be a way to edit the profile, it could under advanced options. i hope this helps.
Apr 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
Speakerphone???
did you try the buttons on the side?  or when you are making a call, hit menu and that should bring it up for your speakerphone
Mar 07, 2009 | LG KG810 Cellular Phone
Auto Speakerphone
Remove the battery, hold the power key for 10 seconds. Re-install the battery, power up, issue should be resolved.
Jul 01, 2008 | RIM BlackBerry Pearl 8100
Speakerphone
While the phone is on and open it should say "speaker" in blue above the button on the right. When you push that button it should turn speakerphone off. And if you have hung up the phone it should automatically turn off until you turn it on again.
Dec 12, 2007 | Motorola Mobility RAZR V3
T-Mobile Dash Smartphone Logo
641 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
