Question about Fossil BQ9184 Wrist Watch
How much does it cost to replace the crystal on a men's fossil watch measuring 1 inch by 3/4 inch. Thanks.
  • 3 Answers
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
SOURCE: fossil blue collection wrist watch, services in hyderabad and cost
You are now way NEAR a center. You will have to go to Fossil.com and find one in a nearby country.
Posted on Apr 23, 2008
escapement
  • 2334 Answers
SOURCE: mens bueche girod 9k gold watch the gold band is 1 inch short
You have two options and for both you need to find yewellery repair shop.
Option1) Some jewellers sell NOS (New Old Stock) gold watch bands. If your vallet is thick enough for this option- shop around and buy one.
Same jewellery repair shop will be able replace the old band with the new one, even if the band is soldered to watch case.
Option2) In the same shop ask if they can built up (lengthen) the clasp. In this case you will spend less money, but you will loose on looks.
Note: As mostly all gold watch bands are maschine made, it is allmost impossible to repair or lengthen them in a good looking way. Anyway- consult the jeweller first and see what he says. He may have some NOS witch is exactly matching your old watch band pattern.
Good luck.
Posted on Jan 02, 2009
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Apr 04, 2009
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
The crystal on my fossil. Watch is got a scratch on it can I send it to you for repair or how do I. Do this
Sure David, send it to us. The cost is $85.00 plus shipping and handling of $8.50.
Or your local jeweller could probably do it for half the price as crystals are standard sizes.
Warranty & Repairs - Fossil
https://www.fossil.com/us/en/customer-care/warranty-and-repairs.html
  1. Cached
  2. Similar
Battery, case, crystal, strap, or bracelet; Damage resulting from improper handling, ... click here); Repairs if the watch was not originally purchased from an authorized Fossil retailer ... If this is the case, you will be able to select a replacement.
Non Warranty Repairs
Apr 08, 2017 | The Watches
Which is a better gift for my boyfriend? Please do help. :)
the swiss watch. also a new fishing rod and a case of beer
Apr 06, 2017 | Timex Indiglo Watches
I have an old fossil bq-8793, years ago I was going to replace the battery myself. I lost the battery back then, there seems to be no indication on the watch itself as to what size it takes inside or out....
Back Plate:
About 1 1/4'' inches wide. Inside inscription/stamp reads:
FOSSIL INC. HONG KONG 1
Battery:
Energizer 373
Movement plate:
There are 3 inscriptions/stamps
1) S (May be a # 5)
2) 1A
3) TMI TIME MODULE INC. JAPAN VX3J
(The above number stamp may also read UX3J)
Mar 29, 2011 | Watches
I need a new crystal for this watch.
mcdevito75 here, Best Bet, look for a small watch repair shop in your arae, chances are they"ll have to order from Fossil.
Aug 10, 2010 | Fossil AM3695 Wrist Watch for Men
Looking for battery for Fossil Watch Style # FS4317 Watch for Men
Link
Hi mm01891,
Please browse above link for your fossil battery replacement. Kindly refer this matter to your authorized Fossil dealers.
Thank you
May 24, 2010 | Fossil Watch Style # FS4317 Watch for Men
How do you take the face of the watch off? the second hand fell off and I would like to fix it
This is called watch crystal or watch glass, not face. Do not even try to get it out, as this is not possible from the outside of watch. Nobody takes off watch crystal for refitting hands. For this you have to open your watch case, get the whole movement out and only then refit the hand. If you are not sure how to do that, better go and see watchmaker, or you may damage your watch and then repairs will cost much more than the cost for hand refitting. Rate me, plz.
Feb 19, 2010 | Fossil Metal Casual Quick Turn Sport...
The glass front came out of my Chronograph Black Dial fossil watc
Go to a watchmaker/technician. They will have a press that they can use to apply even pressure putting the crystal back in place. Be careful that you do not lose the teflon seal sitting where the crystal goes and do not let any dirt or contaminants get to the face of the watch. Be sure you ask them to pressure test it to be sure it is water resistant.
Apr 07, 2009 | Fossil Chronograph FS4249 Watch for Men
Tachometer Chronograph Operation.. HELP?
a Tachometer chronograph is a time and speed measurement.
Jun 28, 2017 | Fossil Metal Chronograph White Dial ES1793...
Fossil BQ9184 Wrist Watch Logo
508 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
