Question about Kenmore Refrigerators
Ice maker makes ice shells and the production is low. I have tried manually filling for one cycle with warm water and waiting 24hrs. Have turned it off and on and waited 24 hrs. and the water filler in the door also runs slow s I have also changed the filter in the ridge section. model number is 253.57389601 serial number is 4A62700262
  • hpridgen Sep 30, 2009
    model number 253.57389601
    serial number 4A62700262
    Kenmore Side by Side Refrigerator
    The ice maker is ing small quantities of hollow or shells of ice also the water in the door is very slow. The filter in the door has been changed in the last few months.
  • 11,896 Answers
Either the water filter is dirty and needs to be replaced. Or the water level sensor faulty or unit is not getting cold enough
Posted on Sep 30, 2009
  • Nate Stansfield
    Nate Stansfield Sep 30, 2009
    Do you have the bar on top of the tray. Can you move it and change the flow?
    If the door is slow, then the circuit could be worn or frozen. If it is vacuum controlled, then the actuator could be leaky. You can test any electrical unit with a voltmeter to make sure all units are getting power. Defrosting the unit once a year is a good idea as well.
  • 15,935 Answers
The water flows into the form which is very cold and the water in contact with the form freezes first creating a frozen outer surface to the cube. The top of the cube is open to the air not yet frozen completely when the ice is ejected into the ice box prematurely. The still liquid water with the center leaks out through the yet to freeze top.
To correct this the timer needs to be set for a longer period (needs more time to freeze) or the temperature in the freezer needs to be turned up.
Air in the line to the freezer (you indicated filter change) will cause this.
If the thermostat for the icemaker has failed - it will eject the ice prematurely too.
One last thing... the heat exchanger under the front of the refigerator (or on the back--depending on model) need to be vacuumed of all dust that accumlates which can make the refrigerator less efficient and the ice not freeze fast enough.
Let a few batches be made, and take note if the cubes are full.
It is likely air in the line - until it is purged - the water timer only opens for a specific time - not water amount. Air in the line will not allow the tray to fill with water.
Thanks for using FixYa!!
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Frigidaire ice maker model jbnd-28 stopped working
Hello - If your ice maker has stopped producing ice completely, please check these, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. A clogged water filter or a blocked supply water valve may also lead to low ice production.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact a professional to diagnose the unit.
Jan 03, 2013 | Refrigerators
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Kenmore Refrigerators
Ice maker makes hollow ice cubes why?
That is what is commonly known in the biz as "Shelling". This is cause by low water pressure. Probably a clogged water filter or worn out water valve, kink in supply line. That sort of thing.
The water should fill for 7.5 seconds. If all of the above mentioned is good then the ice maker itself could have a problem between the copper plate mounted under the main drive wheel and the probe that makes contact with it at the end of the harvest cycle.
Ice maker manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 15, 2010 | Kenmore Refrigerators
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Whirlpool GS6SHAXMQ Side by Side Refrigerator - Ice Maker Problem
This happened to me after i had to move the freezer and it was unplugged for a while. When it was plugged back in the ice maker would not work.
Assuming both the ice maker itself and the rear water AC solenoid switch are actually not broken and are functional, and you are getting water from front door dispenser, then check the inside supply tube (black) is not frozen and blocked. Check with q-tip or feel to see if frozen.
If supply tube is frozen, thaw by holding up small full clear glass of heated water placing the frozen tube into the heated water. The clear glass will allow you to see when ice slips out.
Next try resetting the freeze cycle. Turn off the ice maker switch, remove the maker by carefully disconnecting the inside power cord. You will need to remove the inside door flap. Rinse the maker with warm water, allow to come to room temp.
Re-install maker, connect power cord. Turn on ice maker switch. Make sure Infrared sensor is not blocked. Now wait for temp change and listen for water to fill tray. It took maybe ten minutes for me. You will be able to hear the water fill with the door closed.
Again, this assumes nothing is actually broken.
This worked for me. Good luck.
Jan 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
GE Profile Performance Refrigerator - Ice maker problems
About every two hours you should hear the ice maker cycle. The easiest way to check is to turn the ice maker off using the arm up in the off position. After a few hours open the door lower the arm and observe. The plastic fingers should advance ejecting the ice into the tub. A few swconds after the ejection you can hear the valve and should hear the water fill the tray. If no advance with the ice maker than ice maker,warm temperature, or wiring. If no solenoid sound (ice maker ejector rotates)than electrical or solenoid valve. Solenoid valve and no water - frozen fill hose, blocked hose or unlikely but possible faulty solenoid valve. If you can hear the valve it should pass water!!
If the ice maker doesent cycle CK the temp of the freezer! Must be cold enough for ice maker to work. zero or colder will work for sure and 0 or so is the right temp for freezer. Above 20 don't think it will cycle and would be an indication low freon or bad compressor in unit.
Jan 15, 2009 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
