Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Input issue "Video 1" won't disappear from screen. What do I need to do to get it to disappear?
    Champion:
  • 224 Answers
This will be a button on your remote,should say something like CALL or INPUT,something like that....
Posted on Sep 30, 2009
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
Lg 42ls575t won't go to "input" screen or "home" screen so cannot select HDMI channel. "Loading" message appears for 30s or so then disappears
solved.
1- turn off you router
2-go to settings
3-ok on the ? (support)
4-inatialisation of premium.
Problem solved
Apr 15, 2013 | Televison & Video
I do not have the tv remote and can not get the "video:1" to disappear from the top right of the screen when I have the cable turned on. Any suggestions?
Greetings Cray - You didn't specify which TV or Model you have. Most TV's have a group of manual controls, on newer TV's usually on one side, which allow you to perform most functions without the remote.
One of them is is usually labeled INPUT or DEVICE. If your TV has such controls and you push the button until it comes around to the TUNER input the video:1 should disappear. Of course if you're using a cable box connected to the TV you would want to go to HDMI or COMPONENT, depending how your TV is connected to the cable box.
Good Luck and Thanks for using Fix Ya
Mikeywaf
Apr 10, 2011 | Televison & Video
Video input indicator remains on screen
Press the "DISPLAY" button on the remote control. This will cycle through the display choices and then turn it off.
Apr 04, 2010 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Permanent blue haze on screen; looks like
The fact that you continue to have sound while the picture disappears points to one of three potential issues.
Issue 1: the LCD Panel.
Issue 2: The Inverter Power Boards (though these tend to cause power/shutdown/no video at startup than video distortion)
Issue 3: the Time Control Board - a small board at the top of the LCD panel on the back that relays data to the rest of the screen.
Any one of these three repairs, you should call Sony if the unit is outside of manufacturer's warranty. They are expensive to perform, and the parts are not cheap. Hopefully you have an extended warranty to help with the issue.
Jan 24, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Video Input Label Displayed Constantly
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Video 7 remains on screen
if your on input "video 7" but there is no picture, this is normal. however if you have a picture and video 7 remains on the screen,then on the original remote there's a button labeled "display" press that. video 7 should disappear
Jun 01, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Video input selection remains displayed - can't get rid of it
The solution to your remote problem is to go to wal-mart and when you go through the check out lane there is usually some last minute items. there is a silver remote that is usually hanging in those aisles and that has been the only one I have found that works.
May 20, 2008 | JVC AV-27530 27" TV
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
