Question about HP Officejet Pro L7680 All-In-One Printer
Exactly the same frustrating problem. New cartridge = no ink
Help! No idea what to do. Printer refuses to recognize new cartridge as full. Say empty and will not print. Any suggestions??
  • musiclady535 Oct 02, 2009
    Thank you both for your responses. I removed the unrecognized cartridge, which was brand new and HP, turned the printer off for 3 days - let it rest - turned it back on last night to fax something. Had to put the cartridge back in in order for the printer to allow faxing ~ and ~ it recognized the cartridge and worked perfectly!! Go figure . . .
    Problem Solver:
  • 18 Answers
HP is very sensitive to most "replacement brands". I would try original HP brand ink.
Posted on Oct 01, 2009
  • HP Master
  • 419 Answers
Two possible causes..
1. The cartridge chip is telling the printer that it's expired
or..
2. The rubber bulb in the base of the cartridge can be pushed all the way in without any ink leaving the cartridge. If that's the case the non-return valve in the cartridge itself has failed. This condition results in the printer thinking it's empty so you need to take the cartridge back to the supplier and get a replacement.
Hope that helps even if I've missed a third possibility.
Posted on Sep 30, 2009
Dcp j125 wont recognize the ink cartdrige
Yes, it can be VERY frustrating. I would start with cleaning off contacts on the cartridge and on the printer where the cartridge plugs in. ... If it is a refurbished cartridge (or refilled) it's sensor internally could just be worn out. If you have tried multiple cartridges that are new or known good, it is possible your printer has a hardware problem too. ... If you know someone else with the same model of printer, try the cart's in the other printer to see if they are sensed good.
Apr 09, 2012 | Office Equipment & Supplies
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Says "Used ink tank full". Light blinks and won't print. No idea how to empty.
It sounds like you refiled an empty ink tank. The printer will refuse to accept ink cartridges that have been used and refilled. Unfortunately there is only one easy option: Buy a new cartridge. If it is a new cartridge and has not been refilled (straight out of the box), contact the supplier (where you got the cartridge from).
Good Luck!
Jun 20, 2010 | Canon i860 InkJet Photo Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X2550 ink cartridge refill
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Printer refuses to recognize new ink cartridge
Remove printhead, see if it is dirty. Clean it and the problem should go away. Also Try clening the contacts on the area where the cartridges touch them.
Jun 15, 2017 | HP OfficeJet 7310 All-In-One InkJet...
Cyan ink cartridge is flashing, only prints in blue.
Hi cmwierson, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
328 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
