Question about Sewing Machines
Have a GBC Shredmaster 2260X shredder. Began showing "door open" when door was in fact properly closed. Seemed as if "door close" switch was the problem. But would go from "door closed" to "door open" indication by itself during a day as if temperature variation was a factor. Finally, it just shows "door open" at any time. I have removed the switch and checked it. NO to common and NC to common work fine. The switch is fine. I have shorted the proper wire to common without the switch, and the machine still shows "door open". The problem must be on one of the two circuit boards. Any thoughts on this? Thank you. David Seales
  • 1 more comment
  • dmseales Oct 01, 2009
    There are only two circuit boards. I have been over every semiconductor, chip, diode and most of the can capacitors. Nothing "closes the door". Do you have access to a schematic so we can figure out which component(s) are the most likely suspects? Are we hearing from anyone else who has had the same problem and has solved it? David
  • dmseales Oct 02, 2009
    Not sure this next section went through to you. Have heated and/or cooled each transistor, diode and chip and most of the can capacitors on the two circuit boards. No luck. Do you have access to the circuit diagrahm and/or trouble-shooting material? David
    This is a shredder, not a sewing machine.
  • 555 Answers
This issue is caused by a overheating semiconductor in the board. It may be a simple transistor or the entire chip. To locate the broken board, just follow the wires from the door switch.
If you feel confident about electronics repair, use some canned air to cool down each component, one by one, first transistors, then integrated circuits. As soon you see the shredder stops showing "door open" after cooling a specific part, you will know which one is broken.
If you have no experience about repairs, I do not recommend you to continue using or trying to fix it. Just remember; the safety features are not working properly and it is not safe to operate or play with it. Don't lose a finger just to save some bucks.
Posted on Sep 30, 2009
I have a pfaff coverlock 4862 serger and the power which is triggered by the folding door in the front of it keeps shutting off. What sould I check?
There is a safety switch activated by the front door that apparently is not being fully de-activated. Perhaps the door is not straight or not completely closing.
Jun 04, 2017 | PfaFF Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
Hoe do I replace the bobbin carriage
Don't know which model you have but most machine bobbins have a metal "flipper" on the front. You need to pull that open with your right thumb and index finger, then insert the bobbincase with the . You might have to wiggle it around (don't let go of the flipper until it is seated and will no longer wiggle). When it has popped into a spot where it will no longer turn, release the flipper.
Bobbin Case Threading and Inserting into Machine
The only part of this video I would contradict is, not stuffing the bobbin thread into the bobbin area. If there is an indentation in the case by the door to put your finger to open the door (like what her machine shows), just hold the thread so it fits through that finger indentation while you close the door. Some machines actually have a little lip by that finger indentation where you lay the thread.
Jul 19, 2015 | Kenmore Sewing Machines
How do I know if this is a Machine issue, a Memory card issue or an error in the design file?
Read the files back to computer to check they are there. Open folder by pressing it , should then show designs
Jun 23, 2015 | Janome Memorycraft 9700 Computerized...
Gears stuck message but gears not stuck
This message is often the result of people trying to close the bobbin door too quickly before the bobbin / hook mechanism has swung in properly. There is a complex system of gearing called the 'console motor / gear' that does all the clever bits like swinging the bobbin out, dropping the feed dogs and operating the bobbin thread cutter and this can get dislodged. Switch the machine off and open the bobbin door. Above the black plastic cover for the rear of the hook mechanism, you should see a small latch which is operated by a mechanism that slides left-to-rightacross it. Check that the 'pip' on the sliding mechanism has not overrriden the latch and is on the outside of it. If it is, you can sometimes carefully push it back to the right-hand-side of the latch and all will be well, however what frequently happens is that the 'drive' end of this mechanism gets dislodged from the console gear and its then a dismantling job to put right ... dont mess about with 820's they are very difficult to set up !!! Something else to try, is to remove the needle and bobbin, switch on the machine with the bobbin door open, then close it and open it again and see if the hook mechanism will swing out. Also, again, without the needle fitted (very important), try rotating the handwheel backwards, but if you come up against any resistance, STOP ... the user manual is incorrect in its advice where it says " use considerable force" - this is an error in translation and I've already had one customer who did 400 pounds of damage in following that advice.
Aug 19, 2012 | Sewing Machines
Today, my 830 stopped sewing and the bobbincase opened after a whirring noise during embroidery. I adjusted the thread and tried again. It continues to open and is activated in regular sewing mode when I...
It may be that the door closure sensor has got fluff in it, so the machine thinks that the bobbin door has been opened - the automatic bobbin preenter will then rotate the bobbin case out, and open the door in the process. You should probably have this looked-at by a properly certificated 830 service engineer - it's a very complicated machine, however, you could try VERY CAREFULLY, with a long fine paintbrush, just brushing any fluff and lint out of the sensor. Switch the machine OFF with the bobbin door closed. Open the bobbin door and look on the left-hand-side of the hinged-bottom of the door - you'll see a semicircular black plastic part secured to the left-hand end - it's got a couple of notches in it. When you close the door, these notches interrupt a couple of light sensors on a small circuit-board that you can probably just see behind the white plastic cover. With a fine brush, with long bristles, VERY VERY CAREFULLY, push the bristles through where the semicircular plastic part moves between the sensors, and with luck, this will remove any fluff that's causing the problem. If that fails, it is possible that the 'console mechanism' has gone out of alignment - this seems to be rather common on these machines and can happen if you've had a needle crunch which sometimes happens if you apply too much pressure to the thread when starting an embroidery - in that case, the only solution is to have the machine looked-at professionally. Good Luck
Oct 10, 2011 | Bernina Artista 180
Door sensor problem on juki 655
you have to get the door fixed, juki is set up to power off if the door is open for safety reasons
May 06, 2010 | Juki MO-655 Mechanical Sewing Machine
I reloaded my bobin and began to sew. The thread
Sometimes it may look like the bobbin is the problem, when it is actually the machine was threaded with the presser foot down.
Refer to the manual for your machine and recheck the direction the thread is be feeding from the bobbin and that it is going through the proper guide(s).
Always thread a sewing machine with the presser foot up.
When threaded with the foot down, the tension is closed and the thread cannot enter. When you sew, the stitches are loose and loopy.
Feb 24, 2010 | Baby Lock Sewing Machines
Door open alarm come on when door is closed
I think you have a faulty door switch, you should try to replace it. Normally located at the top of the door frame.
Nov 06, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
