Where would i get the cover for the batteries
Hey,
as i read the specification on this model, it is not possible to remove power totally from the cd player and then power up and continue. (ignition is in your car ?)
But, you can connect power to the cd player,after the ignition switch. Normally this supply is available behind the standard car radio. You can use a standard 12 volt (depends on you car supply voltage) bulb to search for the correct wire.
Often this information are also available in the instruction book for the car.
Best regards michael freesoftware
Why pay when you can play
