Question about Dual XNBP12D Car Subwoofer
When ever I connect the fuse in the power cable to my car, my car doesn't start. But when I remove the fuse it takes a couple tries then the car starts again. Is the battery my problem?
    President:
  • 1,114 Answers
NO! I hope I am incorrect, but it sounds like a "Dead Short" in your power wire. If you are not fused at the battery and at the amp, you are creating a bomb!. That said, if I'm wrong and you have fuses at the battery and amplifier. God Bless Ya!. What you will need to do is go to any battery house or even Walmart. They can load test the battery and let you know if it has an internal failure causing no cranking amps, yet still reads 12volts on a meter. Second thing to do is check your starter feed from the battery for corrosion, check both sides and make sure contacts are clean and no corrosion has "wicked" up the wire. This can cause your vehicle to eat batteries more than any other issue I have ever encountered. Lastly, never run a car audio system that includes an amp without your vehicle running. That's the number 2 cause of battery failure. Hope this helps. If you need to dig any further, post a comment with all the specifics: Year Make and Model vehicle, then list equipment models. Best of luck
Posted on Sep 30, 2009
2003 Pontiac Grand Am Gt gave a guy a somewhat jump yesterday and now my car won't start the battery tested good however it doesn't even attempt to start. Help!
i seen light flashing look like security light.look like vechicle in theft mode problem in the theft security.try to turn ignition switch to the on position 10 minutes until security goes out.then turn off ignition wait 5 seconds see if engine starts if yes problem in the theft security system.if theft security system working okay problem could be starter or starter solenoid.could have faulty neutral safety switch or clutch start switch faulty.make sure battery volts is 12.6 volts let auto parts store do load test see if battery has a bad cell plate shorting
Sep 23, 2013 | Cars & Trucks
1994 v6 camaro car wont start because of security light
Without going into a lot of detail, I take it that this Security light gadget is a anti burglar device to really just stop the 'joy-riders' from nicking your vehicle. Follow wires back to were its connected to, the power supply end. [If fuse box, try removing fuse, or is it inserted into a cable bullet? remove from bullet socket]. If unit works by completing a circuit, replace this mechanism [the whole unit], with a new length of correct voltage /ampere type cable inserting [or connecting replacement as other connection is removed, so you will not forget just where the cable came from.
Nov 11, 2011 | 1994 Chevrolet Camaro
Hello ! I have a problem with my apc smart ups SUA 1500VA. It changed to battery use from AC line altough the AC line was working just fine. I don't know what happend. I found it like that when i came...
Battery not connected properly. Check that the battery connector (rear panel) is fully engaged.
Press the on/test button once to power the UPS and the connected equipment.
Make sure UPS has nothing connected to it. Check the Fuses for the battery inside in the back of the UPS
Unplug UPS and batteries. Push the on button to clear the logic. It may or may not flash the LED's Once the fuses are checked, check the logic boards for any burn or discoloration.
Sep 25, 2011 | APC Smart-UPS 1000VA UPS System
The car is starting 1/10.. Firts i turn ignition key and the light in the dash are lighting up good,i turn the key and nothing happen.I take the off the ignition and it make a tic-tic-tic on the...
We have to assume the battery is usable, if not, anything else doesn't help. A couple of possibilities- First, get a simple, cheap device that uses a 9V battery and the car's cigarette lighter to prevent losing anti-theft codes. Once this is plugged in, remove the negative battery cable first, then the positive. CLEAN the battery connectors and terminals. Try to start the engine. If it still does the same thing, remove the negative battery cable again and follow it to its next connection and clean that point. While it is off, remove the other end of the positive cable which goes to the starter terminal and clean both points.
While under the hood, look for the cable connecting the engine block to the body of the car and clean both ends of that cable.
If the problem is still there, it can be related to one of these; the ignition switch, the starter solenoid or a corroded fuse connection. The starter is not protected by a fuse but the solenoid may be.
Good luck-
May 28, 2011 | Nissan 300ZX Cars & Trucks
Take off jumper cables it dies
You're alternator is dead. Once started the alternator should generate enough power by itself to keep the engine running.
Jul 06, 2010 | 2001 Dodge Intrepid
I cant seem to locate the fuse block for my 1987
Try turning on your hazard/warning flashers. The DOT 3 fuses are usually right next to each other. Follow the clicking sound.
Feb 27, 2010 | 1987 Ford Crown Victoria
Intermittent Power Loss
check all grounds wires if knot problem try to start with jumpers to starter to battery mabey you have bad cables to starter look at cable at starter side loose? or bab connection?
Jun 03, 2009 | 2004 Acura TL
I have telstar tx5 ghia 1990 2,2l 4 cilind automatic, power everithing,car is done 240000.yus wont start one mornig doing klik didn t start and couple time kliking alnaser (starter) and i have used cable ...
Hi
Easiest test is to reconnect jumper cables and switch lights on, if these work and no noise AT ALL from starter, NO clicking at all then could be the jumper cables are too light like most are. Try 2 sets of jumper cables. Ensure that the cables are correclty applied, Red to Red and the black is the last connection to a good steel part on your engine, NOT the battery.Always ensure the car being used to jump from is running at all times while cables are connected.When it starts remove this one FIRST also.
Cheers cbacer
Apr 30, 2009 | Mazda 626 Cars & Trucks
Won't turn on?
Unfortunately this sometimes happens because the printhead has decided to die on you... There's a warning in here too so whatever you do, don't try the printhead in another printer because if it was the cause it will fry that printer too.
A couple of things to try though:
1. Locate the printer power pack in the printer... This is a module that will slide into it's slot in the printer. Removing it may require you to take the case top off (which I can't help with, sorry) but if you can manage it continue..
OBVIOUS BUT IMPORTANT: Disconnect from the power before you do ANYTHING!
2. Remove the power pack from the printer and disconnect from the cable or cables internally but make a note of how they connected so you can reconnect.
3. Re-connect these cables after a couple of minutes, replace the power pack.
4. Test the machine by plugging it back into the mains and turning it on... If it comes back to life, you're sorted... If it doesn't your options are very limited.
Oh and obviously check that the fuse hasn't blown in your power leads plug (if you're using a fused plug - ie: in the UK, etc.)
Hope that helps... and good luck.
Feb 16, 2009 | Canon MP970 Photo All-In-One InkJet...
Dual XNBP12D Car Subwoofer Logo
97 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
