Question about Acer TravelMate 2300 Notebook
Laptop My copmuter is 4 years old, an Acer. Before the warrenty ran out 2 years ago, it was telling me to switch over to an A/C outlet, and I was already on an A/C outlet. I sent it in to tigerdirect, they fixed the problem, and I upgrade my laptop about a year and a 1/2 ago. It is now doing exactly the same thing again. I'm plugged in to the wall, it lasts about 20 minutes before shutting down to recharge.
  • Anonymous Dec 20, 2007
    yes even when the computer is plugged in to the wall, it goes in to hibernate. I turn it on again, and it starts charging. All of this while it is plugged in.
More than likeley it has developed a dry joint on the motherboard where the power supply plugs in and every now and the the conection is lost its a common problem when the laptop heats up
Posted on Dec 19, 2007
  • 21 Answers
Are you saying it shuts down even when you're plugged into the wall?
My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Nov 16, 2011 | Computers & Internet
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
Acer 5920 wont turn on, we bought an extended
This is a common problem with Acers but usually it is the battery and the adapter. Replace the battery as well as the adapter and you shouldn't have any issues. Surges can be the main cause for this or running the laptop hot has also been the culprit.
Apr 02, 2010 | Acer Aspire 5920-6727 Notebook
How to get the warranty period to be expand as allready in warranty period of three years but my dealer is given for 1 year.
Hai, mostely all laptop except toshiba comes with under 1 year warrenty but you can extend your laptop warrenty periods by paying extra money . Please click on below given link to get more detials.
http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Activate%20Your%20Acer%20Advantage
If this answer is helpful, please rate this answer
Feb 26, 2010 | Acer Aspire 5920-6335 Laptop
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
My AOA 150 NOT STARTING!!! :(
It's a BIOS issue. Please update your bios through the emergency update feature here:
http://www.qrpcw.com/2009/ 01/acer-aspire-one-bios-recovery.html
Apr 06, 2009 | Acer Aspire One PC Notebook
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
Network my desktop with my laptop
Internet -> Port 1 or 16 ComputerA -> Port 2 ComputerB -> Port 3
I say port 1 or 16 because on older equipment there is an uplink port that is usually either the lowest or highest port number depending on the manufacturer. Set both computers IP addresses to use DHCP in this scenario. If you aren't connecting to the internet, both computers need to have their ip address set manually to a number in the same "neighborhood" (i.e. set A to 192.168.1.2 and set B to 192.168.1.3), then they will see each other.
Jan 27, 2009 | Dell PowerConnect 2016 (pct2016)...
My Tv just started doing the same problem
Sounds like the On/Off sitch is bad to me. Be Calm my friend these things happen in life. No point in becoming angry over it. The fact is it was probably the least expensive set on the shelf when you bought it. It came with a warrenty as do the other brands And, this sort of problem can happen to ANY brand of television. That's why you get a warrenty. Also, you could have bought an extended warrenty which would have cost you more than the repair job you need for your tv. Call 18002427158 press 1 be preparred to hold about 4 or 5 minutes and ask them for a service tech in your area. I would think that this should be repairable for about $35-$55 OR look in your yellow pages and take it to any TV reapair shop in your neighborhood. Don't worry, BE HAPPY!!!! Don't forget now, very soon, if you don't have cable or satelite you will need a new tv anyway. The nation is going Digital! WOO HOOO!!!! Have a great day! Symphonic tv's are ok. I have had a 27" here for 13 years now still plays great! Although, my 6 year old Symphonic just pooped the bed. But, that's ok cause I can fix it!
Mar 22, 2008 | Symphonic WF20D4 TV
Computers & Internet Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
