Question about Husqvarna Chain Saw 20" Bar
I have a 455 Chain saw and it was running fine and just quit. Tried new plug and new gas. It will not fire at all.
  • Pimpinaudio May 11, 2010
    Have you checked fuel and fuel tank pressure lines? fuel filter? (usually located in tank), Have you checked if the ignition coil is functioning? checked the "kill switch"? all these must be checked.
    President:
  • 2,220 Answers
If it sputtered as it died It is a fuel mixture or dirty carburetor.
If it was at speed and suddenly went dead it is a defective ignition module or associated wiring.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Posted on Sep 30, 2009
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
50to 60 compression on a husqavarna 455 rancher chain saw. Ring job and how hard?
455 is an X Torq engine, this means it runs very cool on the inlet side of the piston, they are quite prone to gumming the ring in if they have been used on a heavy two stroke mix, due to the designit is a full machine strip down to get to the piston, skilled man 3 hours to strip and rebuild.
Sep 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have the 455 rancher and when I start the saw I pump the bulb 6-8 times and the saw will not run right. It sounds as though it is running out of gas. It bogs down when I pull the trigger. The saw is 2...
Before you do anything else i think you need to check the engine is mechanically sound, remove the muffler, take a look at the piston skirt through the open port, any signs of scuffing on the piston and it will require removing the cylinder to assess the damage, they are x torq engines, due to the way the air ports work they are quite prone to carboning in the piston rings, make sure it has plenty of compression.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
The saw s primer bubble split ...i replaced the primer and it ran fine..then just quit... i changed the gas and checked the plug for fire .its ok..........but it will not fire ????
I would see if you have a air pocket in your gas lines.Try removing plug and pumping primer bulb until you know engine is flooded. Then let dry out before you put plug back and try to start. Thank you.
Apr 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My 455 rancher bogs down when i give it gas it's not even under a load new plug air filter, fuel filter, made carb adjustments like manual said running 93 octane gas.it,s still bogging
Make sure the chain break is releasing all the way. When the saw is not running release the chain break and make sure you can move the chain back and forth by hand. If you can there is a small fuel filter in the gas tank that should be replaced. Make sure the fuel lines are not spongy because they could collasp when the engine is running starving the carburetor for fuel.
Mar 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Saw was running and quit checked gas and oil both are full
Check to see if you are getting spark. If you are getting spark then it is not getting fuel. Try sparying starter fliud in the carb. If is starts then stops. Take the fuel line off to see if something is obstructing the line. Also the fuel filter can be changed.
If you are not getting spark with the spark plu relace the plug. Also to check the spark, remove the plug and put a screw driver in the plug wire and ground the screwdriver. a spark should come off the screwdriver
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Jonsred chain saw 455
I am only taking a educated guess at this but I believe that you have a carburetor or reed valve problem and unless you are experienced at this type of work I can only suggest that you take your saw to a trained technician
Jan 22, 2009 | Husqvarna Chain Saw 20" Bar
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
99 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
