Question about Kitchen Ranges
Kitchenaid oven keeps blowing 20amp fuse on back of unit model kerh507ywh0
  • Doug Hubbard
    Doug Hubbard Dec 19, 2007
    i replaced the fuse and it lasts a month?
  • Doug Hubbard
    Doug Hubbard May 13, 2008
    there is a new fuse kit for this replace with the kit and presto..
Jump the fuse to 25 and see if it still happens, if it does it has an internal short.
Posted on Dec 19, 2007
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/khms1850s.html
Jan 27, 2015 | KitchenAid Microwave Ovens
No power
i had the same problem and did what this fella suggested and worked just fine. There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
Feb 06, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Fuse keeps blowing Found out we shouldn't have it
A 20 will work but I would change it to the correct on as soon as possible...
heatman101
Sep 07, 2010 | Panasonic NN-S953 Microwave Oven
This model just stopped working while heating food up. Now cannot get even the power to register when you plug it in. Is this doen for?
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Jul 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
No power to microwave
There is usually a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 28 in the drawing. Keep in mind, there are also a couple of thermostats listed that may also cause no power problems if blown.
One is listed as item 29 (part number 8183703) under the same drawing. The other is listed under the "Airflow" section as item 5 (part number 8183697). The humdity sensor can also be a source of problems when it becomes old. If you managed to overheat the oven any time recently, you may want to check these thermostats and sensors to see if they are still good. They should read 0 ohms when measured out of the circuit.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under may not be available at all the websites I have provided. The parts, however, ARE listed.
May 22, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Kitchen Ranges Logo
120 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
