Top oven bake igniter comes on fine, but the gas does not come on anymore. At first oven was working, but we would smell gas after a few minutes, and we would shut oven off, wait 2 minutes, then turn back on. Now gas will not even turn on. Broiler works fine. Bottom oven works fine.
If the bake ignitor comes on (starts glowing) - check the amperage on
the bake ignitor wires when it's on. If the ignitor is a round style -
amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If
less
than 2.5A or 3A respectively - replace ignitor. If the ignitor does not
come on - check the voltage on the ignitor, should be the line voltage
110-120v AC. Faulty gas valve is uncommon, but still a
small possibility. Ignitor part numbers for round style ones: 4342528,
WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020,
5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if
you can splice the wires.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Top gas oven works but bottom gas oven will not light,
frigidaire gas oven-ignitor comes on but gas does or does not on a whim.
Have the same problem. Bottom oven works fine. Top oven bake burner does not light up.Igniter is on and fine.
