How do i hook up my lynksys wrt110 to my inspiron
I do not know where the blue wire from my lynksys wrt 110 goes into my computer. I have a inspiron 1525 laptop. What wire goes into my modem and what goes into the router, etc
  • 496 Answers
There will be a blue cable running from your modem to the router and then if its not a wireless router then you'll need to take another wire from the routers open ports to the port on your computer that looks like a fatter phone jack like this http://images.google.com/imgres?imgurl=http://etc.usf.edu/te_MAC/hardware/i/img_1752.jpg&imgrefurl=http://etc.usf.edu/te_MAC/hardware/networkconnection.html&usg=__tA8o6hmbQwNy9UAugfPKmYnGnFI=&h=273&w=349&sz=14&hl=en&start=36&tbnid=JN2D3cksxBOrPM:&tbnh=94&tbnw=120&prev=/images%3Fq%3Dnetwork%2Bplug%26gbv%3D2%26ndsp%3D20%26hl%3Den%26sa%3DN%26start%3D20
Posted on Oct 01, 2009
I am trying to install a Linksys wrt 110 wireless router without the installation cd
Connect all the cables then hop on a PC connected to the router. With a web browser go to: 192.168.1.1 Here you will enter "admin" (without the quotes) for BOTH the username and password. Once you are in you may configure the router to your liking.
Jul 28, 2011 | Linksys RangePlus Wireless Router WRT110 -...
Have a maytag dryer with no directions. My cord has black, red, white and green wires - the green was screwed to the outside of the old dryer. This dryer has blue, red, and a white with green - the green...
Hi lasanaritchi...
The blue and red will be your two 110 volt lines (2 X 110 volts equals 220 volt) and the white one will be the neutral, green wire will be ground
Go to this link and see a picture of how to hook up your dryeer cord...
Please take time to rate me.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 24, 2011 | Dryers
Hi, I have a linkysy wrt 110 wireless router. I would like to secure it because at the moment it for some reason has become unsecure. Any help wuld be appreciate
Here is the Linksys/Cisco site download and how to site secure your router.
http://homesupport.cisco.com/en-us/wireless/lbc/WRT110/download
Mar 18, 2011 | Linksys WRT110 Wireless Router
WRT 110 TO DSL MODEM CAN'T FIGUREOUT WERE THE
Should be pretty simple ... power goes in a little round hole ... computers go into the various ports ... uplink goes to the modem.
Nothing called uplink? is there a switch on the back that makes port 1 or port 4 the uplink. Press it in (guessing) for uplink ... out for regular port. More likely you will have a dedicated "uplink"
Point is one of the ports goes to the modem ... if nothing is marked ... keep trying until you get connected.
You will need a short piece of Cat five wire to connect the router to the modem.
Oct 10, 2009 | Linksys WRT160N Wireless Router
I need to know how to change the channel setting
Changing the channel is a good idea. Do you have 2.8 Ghz wireless telephones in the same area as your wireless connection? They can cause similar issues.
You can also change out the Linksys router firmware for a more robust one like Tomato or DD-WRT. Their versions have the ability to put out more signal strength.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Fan light kit will not function
Have you taken a VOM (Volt-Ohm Meter) and checked to see that the "two wires" of which you speak actually have 110-120VAC on them?
I bet they don't and I bet they don't because "up top" (where the connections in from the ceiling box, the BLUE wire (might be brown on some fans) is not hooked up. Unless you have separate switches at the wall, the blue and black wires coming out of the fan must be combined and hooked to the BLACK wire coming out of the ceiling box. White (neutral) goes to white, and green goes to ground.
Good luck, and always OBSERVE practicable safety precautions.
Mar 06, 2009 | Hunter 23827 Classic Original White 42"...
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
Lynksis wrt150n .. setting
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
May 14, 2008 | Linksys Wireless-N WRT150N Router
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
