Question about Casio Exilim EX-S500 Digital Camera
My Exilim SN 33028058A lense is not opening and closing properly. Where can i get this repaired?
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
The Shutter will not open
Most of the time this is just something as simple as dust/sand/grit caught in the lense frame that;s why I usually recommend an enclosed lense when i sell camera's at work. If it is indeed a shutter malfunction then I suggest buying a new camera as the cost of repairs is usually more than the cost of the camera itself.
Nov 28, 2010 | Casio Exilim Card EX-S100 Digital Camera
Turn the camera on, len opens up, camera make beeps
there is a problem with the lense motor. consult a good camera mechanic
Sep 20, 2009 | Casio Exilim EX-Z100 Digital Camera
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
My camera says lense error
it naturally happens to all digital cameras , if they are dropped down to the floor.you shouldnt be able to take any pictures.if you try to switch the camera on the lens should be going in and out at least two times and then it would switch off .the only thing you can do is take it to the nearest service center and change the lens array.it would cost about 60$. the true fact is i had this same problem.,thanks for using fixya!.please dont forget to rate my solution.
May 29, 2009 | Casio Exilim EX-S600 Digital Camera
Casio exilim EX-Z700 lense won't open to take pictures
Hi there and thanks for coming to FixYa.
90 percent of the time, it's dirt, sand or grit that has gotten into the lens mechanism preventing it from opening properly. Try this:
Take an air compressor if you have one, or maybe you can use a friends, anyway, put the nozzle up to the camera and run it around the space between the lens and the camera to clean out any dirt or yuk that may have gotten in there. Best of luck. Leave me a comment if you have any other questions.
Rob
Feb 24, 2009 | Casio Exilim Zoom EX-Z700 Digital Camera
Digtal camera
try opening it with your fingers.
mine did that before too.
just like.. push it open.
hopefully it will stay.
Oct 04, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EX-S500
That is what Casio calls a "lens error". It needs to be sent into repairs.
Jul 29, 2008 | Casio Exilim EX-S600 Digital Camera
Lense error
send it in for repair. their is no easy fix for this sorry. www.digitalcamrepair.com can help.
Jul 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
59 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
