Question about Fantech Electrical Supplies
Lights don't give full light
I have 4 recese lights and don't give full light
i have 2 triways and 65w bulbs
  • 152 Answers
Didn't know you could use a fantech dimmer for regular lights.. try a regular 3 way switch in both places and see if you get full brightness then replace only one of the switches with a 3 way dimmer and see what happens.. you can only use one dimmer on a 3-way circuit
Posted on Dec 06, 2009
How to replace brake lights bulbs. When step on the brake, my window light comes on but the other lights does not come on. The park lights and signal light works, except the brakes lights don't work....
I think your break light bulb is damage and not able to work properly so you need to change it so you can give your vehicle to mechanic to repair break light bulb.
http://www.dutchgrown.com/
Jun 14, 2013 | Cars & Trucks
On my 4 x 4, the passenger break lights don't work but the bulbs are good. What do I look for?
When you lock and unlock the doors, this is usually the side light which illuminates, not the brake light.
Remove the brake light bulb, (which also contains the side light filament) and check the filament. It's likely blown, so simply replace it.
Nov 03, 2012 | 2007 Chrysler Aspen 4x2
Yamaha zuma lights don't light up when turn the key
Hi, Tiffany if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic No electric start no rear brake lights
Archived Scooter Repair Questions Lights
http://z125data.weebly.com/uploads/7/1/2/2/7122816/zuma_125_service.pdf
OEM parts for Yamaha
Yamaha Zuma YW125A Owner Manual
Mar 22, 2012 | 2009 Yamaha Zuma 125
Just bought 4 new 1000W Super high output HPS bulbs. Only one of them is really bright. The others are about 80% by eye. The brightest one is nearest to the transformer stack but the others don't...
A ballast for a 1000 240 volt fixture will lose a small amount of output over time , but should nt be too noticeable . I suggest you take one of the dimmer bulbs and install it into the fixture that has the brightest bulb in it now . If the new bulb is now the brightest of all , then you know your other ballasts have lost some intensity . I have also seen on some bulbs depending on the gas inside the glass( ex. HPS or Metal Halide) which gives off the different color , will take a while on initial start up , to burn at full intensity . It is also possible that you were given used bulbs which would explain the 20 percent loss in intensity . Good luck
May 30, 2011 | Sunmaster 1000w Hps Grow Light Bulb 1000...
Replacing light bulbs?
Replace the burned-out bulb with a 120 volt, 30-watt incandescent bulb (WB36X10198), available from your GE supplier
  • 1 To replace the oven light,
first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
  • 2 Remove the top grille by
taking out the 2 screws that hold it in place.
  • 3 Remove the charcoal
filter (if present) to access the light cover (see Remove Charcoal Filter section).
  • 4 Remove the light cover
located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size and type bulb.
  • 5 Replace the light cover
and charcoal filter (if present).
  • 6 Replace the grille and
screws. Connect electrical power to the oven.
The full owners manual can be found here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40474.pdf
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Engine cutting out at 2500 rpm on my 2004 pt cruser and engine light is on ,problem comes and goes ,this is very frustrating on the highway
You can check the engine code by puttuing the key in the ignition...in rapid recesion turn the key to the on position and back to the off position 4 time ending in the on posistion. Wright the code down and search i on google or at www.autozone.com. Correct the error.
Jul 26, 2010 | 2004 Chrysler PT Cruiser
Change brake lights
If you need to change the light bulb for brake lights:
First you need to open the rear hatch then drop down the tail gate. You will notice that there are 4 screws total for each brake light assembly. 2 on the inside where the tailgate was blocking and 2 on the outside of light. Unscrew them all and the assembly will come right off giving access tot he light bulbs.
Jun 25, 2009 | 1994 GMC Jimmy
Side marker lights do not work
Hi
No 1 ..Take the lenses off, and check the bulbs, and renew if necessary, check the bulb holder terminals for corrosion, if so spray with WD40 and clean, (with the lights off).
If this does not get them going , you will need a 12 volt test light, and test for live feed to the bulbs lamp holder, with the lights switched on.
Expect you will find corrosion is the problem.
Good Luck
Don´t forget to give a FixYa rating please !
John.
Feb 03, 2009 | 2000 Nissan Maxima
Electrical Supplies Logo
83 people viewed this question
Top Fantech Electrical Supplies Experts
Steve
Gene Haynes
Are you a Fantech Electrical Supply Expert? Answer questions, earn points and help others
