Question about Logitech MX518 931352-0403 Mouse
Red light stop for MX518 (logitech) - Logitech MX518 931352-0403 Mouse
    Novelist:
    Champion:
  • 250 Answers
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Posted on Jun 08, 2010
    Sergeant:
  • 338 Answers
either try connecting the mouse to another USB-port or another computer to see whether it works with another machine. IF it does not the mouse is broken and you will have to get a new one.
Good luck
Posted on Sep 29, 2009
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: logitech mx518
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 22, 2008
  • 315 Answers
SOURCE: Logitech mouse M-SBF96 Not Working Properly... I
just buy a new mouse. its not worth the trouble. they're only 20 bucks or even less.
Posted on Jul 14, 2009
Crenshow
  • 250 Answers
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
Posted on Jun 09, 2010
Problems whit logitech mx518 mouse left click sometimes work and sometime no, how do i fix the left click
It sounds like the micro switch needs replacing inside the mouse. At the end of the day it is probably cheaper and less hassel to go out and buy a new mouse.
Aug 01, 2010 | Logitech MX518 931352-0403 Mouse
MX518 stops working for some seconds
The usb port might not be working fine, try the other usb port. Since the light goes off it signifies that the connectivity with the pc is lost.
Jun 24, 2010 | Logitech MX518 931352-0403 Mouse
Logitech cordless mouse wheel won't work. pages
need model-try on another ps if still notworking correctly. call logitech for support.
Jul 16, 2009 | Logitech MX518 931352-0403 Mouse
Logitech mouse M-SBF96 Not Working Properly... I had LogiTech MX518 and when I pluged out usb of MX518 and pluged in M-SBF96, M-SBF96 didnt Work... I was thinking that driver didnt recognised it and i...
Jul 14, 2009 | Logitech M-SBF96 Mouse
Pointer moves when clicking even is mouse is not moving
just open ur mouse
and clean it with cotten
and u will never got thsame problem.....
Jun 26, 2009 | Logitech Gaming-Grade MX518 (9313520914)...
Logitech mx518
  • Some wood grains
  • Grooved surfaces
Cheers!
IrishDruid
May 22, 2008 | Logitech MX518 931352-0403 Mouse
Mx518 cable problem
Most PC repair shops can make you a new one.
The mouse itself is only around £20.00 / $40.00
Jan 13, 2008 | Logitech MX518 931352-0403 Mouse
MX 510 freezing
Same problem been getting worse. Figured out that the mouseware driver is outdated and not compatible with win xp. Use logitech's setpoint for mx518 or uninstall mouseware. Now no more freezes
Oct 11, 2007 | Logitech MX510 Performance Optical Mouse...
Logitech MX518 931352-0403 Mouse Logo
243 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
