Question about Vacuums
Replacement part: Agitator body - Vacuums
  • edenbann Oct 03, 2009
    Don't require this part anymore
  • rkintz May 11, 2010
    What brand of product? What model?
    Scholar:
  • 190 Answers
What manufacturer and model number, please.
Posted on Oct 03, 2009
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
1. Place handle in operating position and turn cleaner over.
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
Why does the belt keep breaking on my kirby
Odds are that the problem is not with the belt or the pulley, but with an agitator (rotating brush) that isn't turning freely. Remove the rotating brush and check to see that it spins freely. If not, you would either need to disassemble it (removing the end caps) to see if removing whatever hair / diebris is stuck between the end caps and the body of the agitator, and if that doesn't cause free rotation, then it means your agitator bearings are likely bad which means you will need to replace the agitator assembly.
May 06, 2009 | Kirby G6 Bagged Upright Vacuum
My belt broke. I have a replacement. I dont know how to install the replacement belt.
There's a plastic cover over the agitator. (the part that should spin, with tough bristles)
Unscrew it. Pull out the agitator. Put the new belt over the 'spinner' (the part that's connected to the motor) and the special pafrt of the agitator. Snap the agitator back into place, making sure it's secure on both sides.
Screw back on the plastic cover.
Wallah!
Apr 25, 2008 | Vacuums
My Model is a U5465-900 - I need to replace the agitator housing.
I don't seem to be able to find a site with entire replacement parts list. Or a cross reference to the U5465-900 model. It has a 15" agitator. The housing has been "rubbed" through at one side of the agitator and is no longer capable of containing the agitator in the proper position.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can check your local vacuum dealer in you city or state and they sometimes will have a micro fiche or breakdown of your particular vacuum or you can contact the Hoover Factory Website listed below --- or check your owner’s manual for a parts breakdown or check the yellow pages in the city or state you live in
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 15, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
