Question about Samsung SyncMaster 245BW Monitor
Monitor problem my monitor is troubling to start,it does not disply sometimes,sometimes working properly.
    Champion:
  • 209 Answers
I am sure it is not your monitor which has a problem, as you said sometimes it works and sometimes not. what i know is that your video card try to remove this and clean it looses contact and thats the reason why sometimes it work and not
Posted on Dec 19, 2007
My HP laptop starts with a white screen then fuzzes sometimes in between
Try to remove your LCD monitor check all connector must be connected properly, sometimes this happen if connector got lost contact.
If problem persist contact advance knowledge in trouble shooting Laptop monitor. This problem occurred when the bulb of LCD got Trouble.
Jan 14, 2013 | HP Computers & Internet
THE MONITOR OF INDOOR UNIT DISPLY ALL THE
This could be caused by a blown circuit breaker or fuse inside the unit, a damaged compressor or fan motor, faulty wires connecting the compressor or fans to the control board unit, a faulty or hung relay on the control board (this can sometimes be solved by tapping the relay with a screwdriver), or the starter capacitor for the compressor or fan motor.
Sep 17, 2009 | Samsung AQ24 Air Conditioner
Monitor display problem..
Change yor keyboard. If any one key remains pressd or if any pin is bent then evrything seems to work but there is no Display and no beeps or error messages either!......i too suffered the same once................sodeep
Mar 18, 2009 | Computers & Internet
Acer AL1912 sometimes doesnt start
Try reseating your cable connections. While you have them off, take some compressed air and clean both the connection ports on the back of the computer and cable connections. Check to make sure there are no bent pins on the cable connectors. If you know how, you might also want to open your computer case and reseat your video card and clean your system out with the compressed air. Make sure your computer is completely shut down properly and is unplugged from the outlet when you do this and before you work inside the case make sure you touch the metal side to discharge any built up static electricity you may have so that it does not cause damage to the sensitive components inside your system. If possible you might want to take the monitor and connect it to another computer system, if it works properly on that system, more than likely it might be your video card. Hope this helps
Jun 25, 2008 | Acer AL1912 19" LCD Monitor
Satellite Pro 1905-S301
if u get normal beep of ram then check your disply resolution .
when u start your pc press F8 key continus then if u get menu choos best configuration loading in menu.then change your resolution to 800x600 or 1024x768 .if u not get menu and your cpu ;s smps still work but not disply on monitor then clear your bioss . get away the cmos cell for 15 minutes from its case.then start your pc .i think your problem is solved.
Mar 21, 2008 | Toshiba Satellite 1905-S301 Notebook
Monitor problems
Mar 20, 2008 | Computers & Internet
Samsung793s led blinking no disply
the vga card is not connected properly i think in cpu .. just reconnect it... and then have a try..... it should work...
Feb 13, 2008 | Samsung 793S 17" CRT Monitor
Samsung SyncMaster 245BW Monitor Logo
112 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
