Looks like, it is a thermal shutdown issue.
Try the following: Keep a fan and direct the air towards the bottom vent holes. Switch on the TV. Keep it on continuously for more than 2 hours and see if the TV shuts off again. If not, then it confirms Thermal shutdown..
ELse please give me the error blink code, ie What coloe does your LED blinks, and for how long it flashes..We can find the type of error directly from the blinking error code
Please leave it as comment, we may help you to solve your issue..
RNJ VINODKUMAR
It would be a good idea to check the power coming from the power supply to make sure you are getting power. Not too much power, around 13.5 volts to system board.
If you are getting severe amounts or none at all, then power supply is bad.
If you are getting power and sound but no picture, then the IC's or STK's could be bad. The capacitors due tend to get overheated very easily now days.
it does not come on at all. i will try later to check the power supply and get back with you
it seems as if though the tv will not come on at all. how will i be able to make this advice happen it sounds very good though and i would like to try it.
this sounds like a reasonable answer but the person has just notified me that he do not want to deal with it at trhis time. it would probably be simpler for us to just get a new one. thank you very much you seem to have sound advice
