Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printer does not print. Not sure if it is hooked up correct. We moved and manuals are lost. Please help. It is hooked to a dell computer.
  • 268 Answers
This link will take you to a site where you can download the manual/user guide for your machine. Chose the link you want on the right side of page.
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/MULTIPASS%20MP730-_E
Best of luck to you.
Posted on Aug 04, 2010
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
I am trying to hook up a Dell 922 to my Toshiba laptop. I have the cd disc I used when i had it hooked to my Dell PC. I can't get the printer to print from Microsoft Office ( word)
A couple of things to consider:
Have you install the printer in one of the computer correctly?
Are you sharing that computer on your network?
Are you sure the two computers are connected? (can you see the shared folders of each other?)
If not, then you must do that before being able to print.
If you did, then:
Did you ADD the shared printer from one computer to the other?
If you did,
Have you select that shared printer as your default printer?
After you check all this points, you must be able to print from either one.
Good luck
Don't forget to rate this answer if it helps.
Nov 26, 2010 | Dell 922 All-In-One InkJet Printer
When printed document is sent to printer, it prints with dark lines below each line of print often obscuring every other line of print .
  1. When connected by a USB cable, reseat both ends of the cable going from the computer to the printer.
  2. When connected to a wired or wireless network, make sure the network is working correctly and that the printer is connected to the network.
  3. (to make sure the printer is on the network, print a network set up page, for more information on how refer to the user's guide, refer to the Downloading and Viewing Printer Manuals section for information on how to download and view the user's guide).
  4. Restart the computer.
  5. Turn the printer off.
  6. Unplug the printer power cord from the A/C outlet or surge protector and wait at least 30 seconds.
  7. Plug the printer power cord back into the A/C outlet or surge protector.
  8. Turn the printer back on.
  9. Make sure the desired printer is set as the default printer.
    • For instructions on how to check which printer is set as the default and change it if needed, Click Hereextlink.gif
  10. Print a test page.
    • For instructions on how to print a test page from Windows, Click Hereextlink.gif
  11. Run the automated printer fix available from Microsoft.
    • For instructions on how to run the automated printer fix available from Microsoft,
      Click Here
  12. Uninstall the printer driver, download and install the latest printer driver.
Nov 08, 2010 | Dell 948 All-In-One InkJet Printer
Printer stopped printing when paper fed improperly. Fixed it, and tried everything to get it back to work. It just flashes one short flash, pauses, then two short flashes. Help! Tracey
      Click Here
Nov 08, 2010 | Dell Inkjet 720 Printer
My printer hp laserjet 5l is printing in number and alphabatic what i do .
This is caused by one of two things. First be sure you have the correct printer driver installed, if you have printed to this printer before on this computer then you should be ok here. The other thing would be that the printer lost communications with the computer and when it reconnected the control codes had been lost. To check this, first power off the computer and the printer. Now check the connections between the two, the computer connection should be screwed tight and the printer connection needs to have both clips fastened. Now power up the computer and printer, try a test print, if it prints then you should be good. If you still get the odd print then replace your printer cable, be sure to get one that is rated IEEE1284. This rating insures proper bidirectional communications between the printer and the computer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | HP LaserJet 5L Printer
I have a new computer with Windows 7. I installed the HP 3500 driver and now the printer won't print. I hooked up the printer to my old computer that ran the 3500 and now the 3500 won't print from that...
If it no longer prints to the old computer, begin by powered down the printer and unplugging the power for at least 1 minute.
Hook it back up to the old computer powered down.
Once powered back on, goto control panel, printers and make sure that printer is set to default.
Try and print again. If it works moving on to the other computer make sure you are using the correct windows 7 driver (32 bit or 64 bit) if you are using the correct one I would try and install the vista driver instead as windows 7 and vista are quite similar
Lets start with that If you still need further assistance please leave a comment Thanks :)
Nov 21, 2009 | HP Color LaserJet 3500 Printer
Can't hook up my lexmark x5100 printer to my dell vista computer.
Make sure that your programs are set to use the lexmark and that they're not defaulting to use the microsoft 'whatever' that's the default setting in most programs.
Also make sure that your WinSpool driver is working correctly. Viruses and worms love to hijack the winspool system, causing many problems including the inability to print.
Apr 09, 2009 | Dell Computers & Internet
How to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Dell 720 Printer failure
it may not really be the lever it may just need some lube. if you use some vasline and rub it on the bar and then move the printer head up and down put more vasline until the head moves slwly then try printing this may work.
Mar 04, 2008 | Dell Inkjet 720 Printer
Connecting HP PSC 950 to my computer and phone line
can you locate the printer port? it is colored purple then it is the biggest among all ports, located at the back your system unit.. make sure when that it is screwed very well..
Feb 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
354 people viewed this question
old marine
old marine
