Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
We have a kenmore 970-628810. the right hand heat
We have a kenmore 970-628810. the right hand heat dial is turned to "clean" first, then the left hand dial turned to "clean" cycle. Oven door locks immediately and the timer registers 3:00 but only hums and nothing else happens.
  • 258 Answers
SOURCE: locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
Posted on Jan 18, 2009
SOURCE: Kenmore 75565 gas oven door is locked. While baking, my son
Had to loosen the lock -- loose enough that the door opened. Only thing that worked. Of course then door wouldn't shut! Cut off the lock and will have to replace.
Posted on Feb 11, 2010
  • 5 Answers
SOURCE: Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Posted on Apr 11, 2010
OK, when you go to use the "Self Clean" function, what happens is special door "Interlocks" engage to absolutely ensure they door can in NO WAY come open during and for some considerable time later. You see the "Clean" is heating up to so,e absurd temperature, about 700 -900 Degrees! This basically BURNS everything up. So when this happens, the Doors stay looked, if you hit cancel and it DID NOT do anything, then try removing from Power, totally for a while and reconnect. If it did do the clean, then often this procedure burns out the thermistor inside, and then the doors stay closed too. You will have to check, which one. Also it may have "Glitched" the controller. Hopefully removing from power will work.
Posted on Apr 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Kenmore 106.53662300 diagnostic test mode
TURN THE DIAL 1 WHOLE TURN THEN TURN IT 1 CLICK LEFT AND 3 CLICKS RIGHT THEN 1 CLICK LEFT , THEN 1 CLICK RIGHT IT SHOULD THEN GO INTO DIAGNOSTIC MODE AS FOR THE CODES U SHOULD HAVE A SCHEMATIC TO SHOW THEM
Dec 17, 2016 | Kenmore Washing Machines
Latch signal mismatch error
first ,check the simple .... reset both dials to off position, then reset the time bake and clock on the upper left hand side ,make sure the start stop clocks are reset , turn back on broil ,bake temperature and see if this fixed the problem,...
Aug 05, 2012 | Kenmore Kitchen Ranges
The Kenmore HE2 Washer Model 11046462501 Selector dial lights blink continuous with status lights Add a Garment, Rinse, Clothes Clean lights lit. What does this error mean ?
This IS the code for drain problem, pull front panel and remove round filter by turning to the left, probably full of change, feel the pump to the right of the filter if it is HOT, replace it...
Aug 09, 2010 | Kenmore HE2 Plus Front Load Washer
Dryer never turns off
It's the timer indefinitely. The no heat problem probably occured due to insufficient air-flow.
Go outside and check the flow. Rule of thumb:
you should be able to have your hand a foot and a half away and still feel air. good luck :)
Jul 13, 2009 | Kenmore 800 6983 Electric Dryer
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
Kenmore dryer
hi. thanks for the question. lay dryer on the floor, front down. remove back panel .remove air duct on the left, where the lint filter goes. remove and clean all lint. clean all venting .check heater for broken coils. thanks the appliance doc
Oct 05, 2008 | Dryers
Beaumark stove
I also don't have a manual, but work on computers so tried some buttons and they did the trick.
On the left hand side is the button that has Mode, and then a series of buttons.
On the right hand side there is a series of buttons, and one looks like heat coming from the bottom. Turn this button to that setting.
On the left side, press the mode button, and then press the button that looks like a thermometer. This is the mode for setting the temperature of the over.
Beside the display windows, there is knob that looks like a dial on an analog clock. Turn this dial until the temperature you want appears.
Oct 23, 2007 | Ovens
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
63 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
