Question about Hoover PE235 Front Load Washer
Hoover hnl6166 front load washer problem
The washer does not take the fabric conditioner. I have cleaned everything & checked all pipes at the back. Can you assist ?.
Regards Craig.
    President:
  • 1,294 Answers
You have to open up the top to check the one pipe going into the softener compartment. You can even peep when the machine is running the soft run to see if water flows into the compart. If this does not work dismantle the compartment totally to check. Maybe the screens at water entry has clogged over time.......
Posted on Dec 27, 2007
Hoover vision hd 1400 aaa manual
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
Jun 16, 2013 | Hoover AAA140 Front Load Washer
Fabric conditioner wont go through all blockage things checked and are clear! Please help!!
2 possibilities-
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 17, 2011 | Bosch Exxcel WVT 2850 Front Load Washer /...
Fabric softener will not dispense in my Gallery front load washer. I've cleaned everything I can get access to and it still won't dispense the softener
John C
Aug 13, 2011 | Frigidaire Washing Machines
Fabric conditioner draw not emptying. Checked inlet holes and cleaned the draw and slot. Still not working.
Hi Ryan from retired Englishman in SW France,
Fabric conditioner drawer not emptying
(If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out)
John C
Aug 08, 2011 | Miele Novotronic Premier 500 Front Load...
Fabric conditioner tray is not empyting despite being thoroughly cleaned and water jets cleaned. Have also tried doing 3 very hot washes with empty machine
John C
May 11, 2011 | Bosch Classixx WFC 2465 Front Load Washer
My washing machine is not accepting the fabric conditioner! ive cleaned the tray and checked for blockages and there doesnt seem to be anything stopping it from flowing.
Please do not take this the wrong way but although you have cleaned the tray I still suspect that it needs another clean,
paying particular attention to the sentences in BOLD ;-0)
The conditioner tray section will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
John C
Apr 26, 2011 | Washing Machines
What does the code f-05 for a hotpoint ultima WT640 1400 SPN
F05 measn some blockage, check and clean the filter at the front; remove the top cover of the machine,(power off) and disconnect the flexible hoses from the dispenser. Check if theyre blocked. The dispenser itself can be seperated - generally held together with plastic clips. Clean out any crud or hardened detergent.
Fabric conditioner is taken from the detergent tray by siphon action. Most likely flexible siphon pipe is blocked. Remove machine top, identify the pipe coming from the softener compartment, detach and clean.
Hope helps.
Apr 15, 2011 | Washing Machines
Hi, do you know where I can get an instruction manual for a Hoover HNL6166 Washing machine?
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 28, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Washing machine fabric conditioner compartment full of fabric conditioner at the end of
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 09, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Fabric conditioner compartment will not empty when in cycle
FJS1225W Front Load Washer This video will show you how to keep your soap draw clear and how to service the parts
May 17, 2010 | Zanussi FJS1225W Front Load Washer
Hoover PE235 Front Load Washer Logo
256 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
