Question about Epson Perfection 3170 Flatbed Scanner
The inside of the glass needs to be cleaned. How
The inside of the glass of my Epson 3170 flatbead scanner needs to be cleaned. How do I take the top off to clean it?
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
Posted on Oct 16, 2012
    President:
  • 3,085 Answers
USUALLY you have to flip them upside and remove 4 screws to split the scanner in half, sometime the screws are hidden under rubber feet on the bottom.
Some just snap together.
Posted on Sep 30, 2009
Drive belt came off internal spool. How do I remove cover to fix
Press tabs within four corners of the scanner and careful remove the top of the glass scanner
Jun 22, 2014 | Epson Perfection 3170 Flatbed Scanner
Suddenly doesn't warm up epson 3170 and windows says it is malfunctioning.
Sounds like the bar inside off the scanner isn't working properly, if thats the case then that means the scanner is bad and it would need to be replaced.
Only thing you can try would be to unplug the scanner for about 5 minutes and then plug it back in. Then turn it on and see if it can initialize properly. If it still cant then you know the scanner is bad for sure.
Jul 05, 2010 | Epson Perfection 3170 Flatbed Scanner
Software available with Perfection 3170 Scanner?
yes this option is inclussive with your epson scan program, learn to play with the different modes of the scanner ex: professional, home mode etc. usually these modes have these options.
Sep 08, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Perfection 3170 scanner will not turn on.
having the scanner repaired will cost more than a new one.
Sep 07, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Scanner Perfection 3170 can I down load a
Go here
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25021&prodoid=35836301
Aug 31, 2009 | Epson Perfection 3170 Flatbed Scanner
How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Jun 21, 2009 | Epson Perfection V100 Flatbed Scanner
3170 Epson scanner. Never a problem before, but
Turned off scanner. Rebooted computer. Turned on scanner again. Works fine now.
Mar 22, 2009 | Epson Expression 1640XL Pro Flatbed...
Epson Perfection 3170 Flatbed Scanner Logo
1,500 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
