Question about Epson Stylus CX6400 All-In-One InkJet Printer
My printer says that 'see your documentation and some alien object found'. However I couldn't find anything inside printer. It also make some strange sound.
  • Epson Master
  • 19,396 Answers
I think that by now you are found a way out of your problem with the printer.
If the printer was making noise, then it is either a foreign object inside or a mechanical fault.
Tiny pieces of paper can trigger this same error , but the printer does not do strange noise.
Please, let us know if you need further help.
Regards.
Posted on Dec 09, 2009
My printer is only pulling the paper in from one side, have tried cleaning the rollers and have checked for foriegn objects in the paper feed, display reads no paper, any ideas?
My problem too, solved it easy, couldn't believe it, a pen had fallen in the paper feed slot, I didn't think it possible, couldn't see it until I took it to bits, be careful but worth a look
Sep 23, 2012 | Canon PIXMA MX310 All-In-One Printer
Lexmark x5495 not feeding paper
There could be something that's blocking the paper path. Try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects inside the feeder - try to use a flashlight to look into the paper feeder.
  2. Remove the cartridges from the printer. Check the cartridge area and make sure there are no foreign objects blocking the paper path and the cartridge carrier path. Close the printer.
  3. Re-brick your printer. Remove the power adapter from the printer (it's the black box found behind the printer where the power cord is plugged into). Re-plug the power adapter after 30 seconds. That should give enough time for the printer to reset itself.
  4. When the printer turns on, re-insert the cartridges and load some paper.
  5. Try to print a document again to verify that the problem is fixed.
Should the problem continue, please contact Lexmark Technical Support for additional assistance.
Nov 15, 2011 | Lexmark X5495 Printer
Paper doesn't feed
Hi, The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Feb 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper will not feed into printer, even with hand pushing on paper. rollers do not grab the paper.
Both ink and paper lights are flashing.. and E sign. full carts and paper. what the heck?
Some part of the mechanism is locked or the encoder strip isn't in position.
Look inside the printer and make sure the cartridge carriage moves freely and that there isn't anything that could stall the carriage, check for pieces of paper or other strange objects. Try resetting the printer disconnecting all the cables and holding [CANCEL] and [PAPER SIZE] while connecting the power cable only.
Oct 28, 2009 | HP Deskjet F2210 InkJet Printer
When it is time for printing the paper feeds in crooked and gets jammed.
You need to look down inside where the paper is loaded with a flashlight and mirror, That problem is usually caused by strange objects falling in where they should'nt be, stopping the paper. I've found jewelry, pens, screws, candy, wrappers, and lots of stuff. way down inside.
Oct 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper won't feed into printer. Always gets jammed
you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
Jul 19, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Unable to clean-need trouble shooting guide
I am having usual problem of unable to clean (Brother MFC-5440CN). I have looked for any strange object but can't find any. Could this be amechanical problem and what is solution?
May 27, 2009 | Brother MFC-5440CN All-In-One InkJet...
Paper ALWAYS jams!
Check if there are any paper leftovers inside the printer from previous printing jobs and make sure there isn't any strange objects that may have fall down in the paper loading tray.
Also put the printer upside down and move it up and down to see if anything that may have fall in the paper path, can get out of the printer.
May 05, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
