Question about Lenoxx Electronics CD-102 Cassette/CD Boombox
Casette belt? Tapes play SLOW like an LP on the wrong speed. I figure I need a new belt but can't contact customer service at Lenoxx (bankruptcy). Anyone know exactly what I need, where to get it, and how to install it? Thanks!
They have declared bankruptcy... My husband lost his job there... Your best bet is to make a big stink with walmart...
Posted on Dec 28, 2007
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
I have an rca portable radio tape and cd player RCD175, and it plays good, but wont play cassette tapes. I put the tape in and press pas and the play button wont stay pressed in. What causes that?
Hello
It is due the mechanism trouble to your set. The casette tape deck mechanism should be troubleshooted. It is a skilled work. Just contact any experienced service technician to make this set right.
Feb 28, 2012 | Audio Players & Recorders
My tape deck doesn't play the tapes correctly. It plays them slow or doesn't play them at all. What can I do to correct this?
you either have a bad cassette motor or the belt has stretched to the point that it can't play them at normal speed will need to be changed.
Jan 03, 2011 | GPX S7799 Shelf System
It plays too fast. I suppose its the belt.
the belt will not adjust the speed unless it is slipping, therefore will slow down not speed up.
there should be a speed playing dial. for lp or 45's.
or have you had it repaired. if someone replaced the pullies on the drive or driven end this could have change the ratio and speed.
Feb 19, 2010 | Crosley 0187SST Turntable
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Play Button not working.
Walmart buys from small electronics companies and puts it under the Durabrand name. Very Sneaky. The company that makes the DVD player is called Lenoxx. There website is www.lenoxx.com. Here is the rest of their contact info.
Customer Service
Evergo Corp.
35 Brunswick Ave. Edison, NJ 08817
Tel :
(800) 315-5885
Hours: Mon-Thurs 8:00 am - 5:00 pm EST
Fridays 8:00 am - 1:45 pm EST
Customer Service Email: Evergo@att.net
Apr 04, 2008 | Durabrand PDV-705 Portable DVD Player
Where's the Tracking Button?
If the speed originally was LP, that would explain the problem. Many new units will not properly play LP tapes. Do other tapes play Okay?...accordianman
Jan 21, 2008 | Emerson EWV601 S-VHS VCR
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
Tapes not in 24p play for 2 seconds than stop, WHY?
The BR-DV3000 DV deck has LP inhibit function which is set in the operations menu. JVC does not recommend the use of LP mode and therefore locks this mode out by default. You can change this setting to allow operation in LP mode if you like but I don't recommend it. Using LP mode on DV tape causes the error rate to escalate due to the narrower track width produced by the slow moving tape. Good Luck, this is a nice machine! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | JVC BR-DV3000U DV/Mini DV VCR
Lenoxx Electronics CD-102 Cassette/CD Boombox Logo
130 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Tony Mitri
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
