Question about Nikon Coolpix S210 Digital Camera
Lens error appears every time camera is turned on
Lens error appears on screen every time camera is turned on, lens will not come out, and camera doesnt work
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 26, 2012
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
cpt100
  • 154 Answers
SOURCE: nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Posted on Mar 28, 2009
  • 70 Answers
SOURCE: my nikon camera lens won't work
You must have cleaned/repaired by a professional.
Nikon is in Melville, NY or you may contact
SP-TS.com, an Authorized Service Center in Florida for an estimate.
Posted on Apr 20, 2009
  • 502 Answers
SOURCE: The words "Lens Error" appears on the viewing screen
The lens does not fully extend, that's why it tries again. The lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Posted on Jul 10, 2010
Jimsta01
  • 405 Answers
SOURCE: my digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 24, 2010
(zoom error) massgae appear when camera turn on
You have a problem with your lens, maybe a decentered lens. Make sure there are no obstructions in the way of the lens. It may need to be serviced.
Sep 21, 2014 | FUJIFILM FinePix J30 Digital Camera
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Aug 19, 2009 | Canon PowerShot A480 Digital Camera
Canon SC100 Lens Error
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
Apr 07, 2009 | Canon PowerShot SX100 IS Digital Camera
Hp 735 camera error e106 then it turns off
When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lens or
  • the lens is loose or completely off the track
Solution Follow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
Jun 23, 2008 | Cameras
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
102 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
