Question about Smith LITTLE TORCH 23-1001D JEWELER'S TORCH
Oxygen will not shut off at torch - Smith LITTLE TORCH 23-1001D JEWELER'S TORCH
  • chriswebs191 May 11, 2010
    Have you tried replacing the rubber "o" ring in the torch's oxy tap? Sometimes, flashback can harden the rubber and make it seal badly.
    President:
  • 2,976 Answers
Replace the valve seals and / or stem.
Posted on Oct 19, 2009
Map flame is good, when oxygen is increased, there is hesitation and constant in out flow of oxygen , then POP , flame goes out. i changed both oxygen & map canister. I placed tips in boiling...
Hi:
Probably you are doing everything right but are you sure you are using the right tip for acetylene? Because it sounds like you have a defective tip or a clogged one.
Sep 07, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
Torch will only light when oxygen tank is off. Gas is coming out with either valve open. When oxygen tank is on, flame goes out. Thank you for any assistance, knowledge you may provide. Tim O'Brien
Is the flame you are getting a carbonising flame? ie. is there a lot of soot in the flame? It sounds like your oxygen regulator is faulty and not regulating, blowing out your flame as soon as you open the oxygen bottle. The acetylene side seems to be ok but have the oxygen regulator overhauled.
Mar 08, 2011 | Firepower FPW03842600 Cutskill Heavy Duty...
I have a victor model 100 torch.The spring appears to be broken in the oxygen handle.What is the screw in valve called and where can i get one
Check this manual. It's not for your exact torch, but the parts are about the same. You should be able to go to any welding supply hose and buy parts or have your torch repaired.
http://www.thermadyne.com/IM_Uploads/DocLib_2340_56-1055%20CA%201260%20-%20CA%201350%20-%20CA%202460%20Series%20Cutting%20Attachmen.pdf
Oct 13, 2010 | Garden
I have a Miller Synchrowave 180 sd and have been having difficulty welding aluminum. Can you please help.
I'm not sure what it's doing to know why it's not working but if I was trying to weld aluminum I use 100% argon in ac with high frequency continuous and a 9 second post flow with 5356 crown weldind rod.
Jun 05, 2010 | Miller Welding Tools
When to replace oxygen sensor?
Oxygen sensor are run past there normal lives after about 5 years. They can be cleaned but most people do not have a vise and torch to remove the buildup of debris without cooking the unit. Normally at 100 dollars for most replacements its not cost effective to do it anyway.
May 07, 2010 | 1999 GMC Suburban
I want to remove the oxygen sensor from exhaust
un plug wire and use wrench to remove sensor u may need to heat pipe up some to get it to break lose cutting torch would be best bet to heat it up but if dont have acess to torch just let car run for 10-15 mins
Apr 11, 2010 | 1997 GMC Jimmy
Not enough heat using natural gas and oxygen
Try mapp gas.........I have a small torch with mapp gas and works well for small stuff. Hardware store/Home Depo.............
Dec 20, 2009 | Smith LITTLE TORCH 23-1001D JEWELER'S...
I just bought a torch. and i was just wondering how to use it. i was just wondering how much oxigen to gas i use
depends of the torch you are using, if you have a single ought or 0 then run the oxygen at about 17 pounds and the gas at 7 pounds, this should give you a good clean cut. Remember to turn on the gas all the way, since gauges run slightly off you may have to increase one or the other, on the handle and barrel assembly you can adjust the gas first light the gas then turn on the oxygen get a good blue flame all even on the tips then turn the oxygen knob all they way on then when cutting be sure to heat the metal forward and move forward at a 17 degree angle, when you hit the cutting lever after the metal turns molten hit the oxygen lever move evenly and slowly if you need help with welding with it let me know and I CAN GIVE YOU SOME TIPS ON GAS WELDING.
Nov 21, 2009 | Northern Tool Dual Turbo Propane Torch Kit
Smith LITTLE TORCH 23-1001D JEWELER'S TORCH Logo
117 people viewed this question
Top Smith Welding Tools Experts
Bill Boyd
Are you a Smith Welding Tool Expert? Answer questions, earn points and help others
