Question about Philips PM435S Remote Control
Cant get volume control to work with my philips htib
I have a philips 1000w htib and I can't get my unit to recognize volume commands or turn off or on the code was 0598 for dvd play but nothing
works for volume control
  • 72 Answers
SOURCE: I am desperate for help!
try some other codes at random, such as panasonic
Posted on Jul 11, 2007
SOURCE: Apex AD-2600 DVD Player
wuts the code for a jvc dvd player
Posted on Apr 11, 2008
SOURCE: i have a philips universal
i have a philips universal control i need to program my tv which is orion
Posted on Jul 30, 2008
  • 124 Answers
SOURCE: need code to program ge remote control and dvd player
Go to the following page to get information on how to program your GE remote:
Codes for 4 digit remotes:
PHILIPS ............. [0371] [0344] [0345]
Codes for 3 digit remotes:
PHILIPS ............. [734] [743] [744] [745] [755] [814] [823] [824] [825]
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
Posted on Feb 02, 2009
  • 44 Answers
SOURCE: need codes for philips remote control ph301s ,
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
I hope this helps
Posted on Feb 19, 2009
  • 85 Answers
SOURCE: philips universale remote CL034 codes for magnavox dvd player
Here are some codes I found
Posted on Nov 30, 2009
0 characters
1 Points
I bought 2008 Subaru tribeca and the DVD remote si not working so i bought a new one from Subaru but it's still not working but the unit is ok any idea?
remote volume control not working Questions & Answers ... > Forum > Tags
I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, . ... Volume buttons of Sony Remote control is not working for Akai TV. ... not working for Akai TV ... Radio volume control on 2008 Subaru Tribeca does not ... ... RCA TruFlat 27F520T 27" TV.
Media Center Entertainment for Tribeca -
Nov 23, 2015 | RCA 3-Device Universal Remote with...
What is causing the volume to to change on its own?
This is a known issue for this model, and you need to ask for a service intervention via your dealer or Philips ( to repair it.
Nov 22, 2015 | Philips Remote Controls
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Remote Controls
Why does my samsung BN59-00856A remote control only recognize some of my commands?
It sounds that your remote control need cleaning. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Pull up older posts there.
Pull up older posts there. One among them have deatails about how to clean a remote control.
Oct 14, 2012 | Samsung BN59-00856A Remote Control
I need the codes for GE Universal remote model RC24914-E
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Oct 08, 2012 | GE RC24914-E Universal Remote Control...
I have a philips universal remote code-CL043 and need the codes for philips dvd player
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Mar 16, 2010 | Philips Remote Controls
Need remote control codes for panasonic sc-dp1
For dvd- 0241,0641,0099,0698,0345,0696,0340 .For audio-0780,0682,0183,0983,0987,0088,0099,0696. Philips NOW,FINALLY has a website for their remotes and for their website if these codes dont work- I've had really good luck w/the long,slender MULTI_FUNCTION remotes,which you would probably need for Home Theater In a Box [HTIB}
Dec 21, 2009 | Philips PM3S Remote Control
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Deactivating tv remote control codes
I am not certain these are the instructions for your specific remote. If you are brave, give this a try.
To Clear all Learned Commands under a mode
Clearing learned commands is helpful if, for example, you
replace your CD player with another brand or model. If
you had learned a feature from your old CD player’s
original remote on to this remote (such as RANDOM
PLAY), that feature would no longer work for your new
CD player. Should you wish to remove or clear one or
more “learned” commands, follow the steps below:
1. Press and hold the SETUP button until the red
indicator turns on. Release the SETUP button.
2. Press and release the button for the mode you want
to clear (TV, VCR, etc.). The red indicator blinks off.
3. Press and release the LEARN button TWICE. The
4. Press and release the SETUP button. The red
indicator turns off. All learned Commands under that
mode are now cleared.
Master Clear - To Clear all Learned
Commands under all modes
2. Press and release the LEARN button TWICE. The
3. Press and release the SETUP button. The red
indicator turns off. All Learned commands in the
remote are now cleared.
If you would rather error on the side of caution, here is the link to Philips Customer Assistance. It will help you locate the correct model number and the appropriate User Manual.
I hope this helps, good luck!
Kym McC
Oct 05, 2008 | Philips Magnavox Learning Universal Remote
Philips PM435S Remote Control Logo
27 people viewed this question
Top Philips Remote Controls Experts
Ross Keen
Tech Leprechaun
Tech Leprechaun
Are you a Philips Remote Control Expert? Answer questions, earn points and help others
