Question about HP Photosmart C4250 Multifunction Photo Color Inkjet Printer
I have a HP Photosmart C-4250 printer that suddenly won't print - the printer obeys the command to print, and paper goes through the machine, but nothing prints. The printer box reports the printer as idle, though the control panel describes it as ready (but not in bold print). What do I do? I've tried changing the port on the computer, turning the printer off and on, shutting down the computer, but nothing works.
  • jlshottie May 11, 2010
    can't find printer on computer files, i lost disk to rerun it again
oldnovii
  • 667 Answers
SOURCE: Photosmart 2575 printer is offline - won't print
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 09, 2008
  • 4 Answers
SOURCE: HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
rebell26
  • 86 Answers
SOURCE: Hp PhotoSmart C4480 printer all of a sudden
You will need to contact HP and request a "regionalization reset". To perform the reset you will need access to your computer and printer as well as a set of cartrdiges for your new region while on the phone with HP. Once the region has been reset the original (US region) cartridges will no longer work in your printer.
Posted on Feb 12, 2010
SOURCE: My HP Deskjet D1341 does not obey the command to
hi
thank you for using Fixya
the prob is you have to cancle all pending printing jobs then restart your pc it will print
some time if u have any pending jobs in pending list it hepence
Posted on May 17, 2010
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
My printer will not print any colors onto the paper! It goes through all the actions and responds right away to print commands but will not print any ink.
If the printer sat up for any length of time the inks have probably dried out and will need to be replaced or they have just run out of ink. You should have gotten a warning from the HP software that the ink supply is low and will need to be replaced soon. If the printer just suddenly stopped printing one day There might be hardware issues. Check your warranty situation in that case, HP will take care of it for you.
Hope this was helpful.
Feb 10, 2011 | HP Photosmart Premium C309A All-In-One...
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
My HP Deskjet D1341 does not obey the command to print. Every time I give an orde to print it does not obey but keeps on adding the number of printing jobs. What should I do?
hi
May 17, 2010 | HP Deskjet D1341 InkJet Printer
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP C6280 printer suddenly won't print on photo paper
I can't get a hit on that exact error message, but I would recommend you reset your printer. Here's a link with instructions on how to do that, and another link to the support page for your printer if you want to search that error yourself or otherwise troubleshoot the problem...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 25, 2009 | HP Photosmart C6280 Printer
Prints blanks after paper jam
check the settings first and then services afterwards loose static and restart complete system
May 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP Photosmart C4250 Multifunction Photo Color Inkjet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
