Question about Philips Televison & Video
I have had my tv for a couple years. no problems.
I have had my tv for a couple years. no problems. last night it got black lines going horizontlly across the screen. thick and thin. also can see some red dots. It didn't go away this morning. still doing it. can you help?
  • obsidiansnow Sep 30, 2009
    It's phillips plasma. the one with the ambient lights on each side. I am not at home right now to check.
    President:
  • 1,462 Answers
This problem can be caused by several things,
-a connector on logic or address boards(in this case the lines would be localized to a half or less part of screen)
-a defective logic board that do not send the right address pulses to address board;
-a defective address board-but again it will impact only half or less of screen,
Tv needs a professional tech to be looked at.
There is 60% of chance you will need a new screen. The problem you may have is dead driver (part of a screen) or poor connection between plasma glass and ribbon wire connector.
There is some solution for it but not for long time. PDP panel and address driver on it not separated. If one of 26-40 drivers is going out, you need new screen.
It is a real question why manufacturers don't separate expensive PDP panel ($2000 and more) and $40 driver IC on it.
It is easier to replace small $40 part than the entire screen. So far they just ignore this issue.
Future plasma panel will be aluminum + glass + gas only.( no more drivers on it )
Other common problem with lines on screen -- buffer boards , high ammount of failure for these boards due to poor electronic design ( 1-- voltage needs to operate controllers on buffer board just to high for small SMD IC ,2---they are not strong enough to drive address electrode). In future it will be changed for more reliable parts .
Please leave me comment, if you need furthur assistance
RNJ VINODKUMAR
Posted on Sep 30, 2009
  • Philips Master
  • 15,557 Answers
What is the exact make and model?
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Had this TV for a couple of years now. We bought it new. It has started switching itself on and off standby. When you press any button on the remote control the screen goes black then comes back on...
With no make or model, it is a little difficult to try and decide what the problem might be but, I would disconnect the touch button panel on the TV, if it has one. That could be the fault.
Mar 11, 2011 | Televison & Video
Old Panasonic tv approx 10/12 y/o? -Model TX-28CK1L Serial no ND-0360158 Last night 50% of screen from top to middle "blacked out"--half picture still visable on bottom half. Very bright thin...
The main coupling capacitor feeding the frame scan coils has failed or the output stage on the frame stage has failed due to dry capacitors or dry joints.
Fault finding and components are not a problem and yes it is very repairable. Any technician that knows how television works can repair this standard frame output stage.
I hope you find a good technician.
Dec 30, 2010 | Panasonic Televison & Video
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
LCD Sony TV - Skwiggly line
Hey there I think the problem is coming from your LCD chips not your bulb, the bulb has nothing to do with the color or skwiggly lines it just shoots out white light,your LCD chips are burnt and the problem will not stop by changing your light bulb you need to replace the OPTICAL BLOCK the skwiggly line will just get worst with time
hope this helps
please rate this solution !!!!
Oct 12, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
