Question about GE Profile JGS968 Gas Kitchen Range
Cannon Camberley 10305G (Double Oven)
Whilst cleaning the hob, i took the front display off (including the wiring behind the display). After reassembling, i do not have any time display or gas coming into either oven, but the hob and grill still has a gas supply. Any ideas on a solution.
  • LizS165 Nov 17, 2008
    I have the exact same problem although unable to get any of the display buttons to work. Screen is just flashing auto.
Trust you have set the clock as this turns the gas supply on to the ovens
Posted on Mar 18, 2008
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Cannon camberley double oven the lower oven will not work and no gas is coming through to it but the top oven works fine can u help. Thanks Steve
Just got one today and have the same problem. Have read on here you need to set the clock to turn on the gas. Now i just need to figure how to set the clock.....
Nov 25, 2009 | Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
MY CANNON CAMBERLEY main oven is not working at all. No Gas, no ignition, hobs are okay, clock is blank.
You need to press the cook period button. You'll see a counter that says 0.00. Press the + (or - button if you have gone too far) to set the time you want the oven to stay on for. When the timer runs out, it will beep with the alarm, and at the same time cut off the gas supply to the oven.
Annoying, but a good safety feature. I normally put 3 hours on to make sure it stays on for the full length I am cooking for.
How do I get my grill working???? Its how I found your question. The dial won't even turn in that direction, and I am sure there is a similar safety device in place. Might be the same one. Will try (just typing helps me think).
Nov 19, 2008 | Kitchen Ranges
Nov 04, 2008 | Kitchen Ranges
Wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Feb 14, 2008 | Ovens
GE Profile JGS968 Gas Kitchen Range Logo
1,111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
