Question about Maytag 30" Built-In Double Electric Wall Oven - Black
Model jjw9627cab. electronic clock assembly went dark. Do I need to replace entire assembly? Will adjustments need to be made if replaced?
I had the exact same problem and after years of ingnoring the almost completly dark display things got worse this morning when the alarm started going off randomly. In searching the internet I found one reference to a bad capacitor on the clock board. Figuring I had nothing to loose, I replaced C3, a 68 microFarad 35V capacitor with one I had available (220 microfarad, 35V) and the display now works perfectly. It is a farly easy repair and if you have access to a soldering iron I would recommend that you give it a try. I think it is safe to use a capacitor with a larger capacitance but do NOT use one with a lower voltage rating (higher voltage is fine).
Posted on Jan 25, 2010
F1 on oven diplay
What brand of oven do you have? On GE and some Kenmore models, the F1 error is a problem with the touchpad or the ERC (electronic range control or clock). On some models, the two parts are sold as an assembly. On some Maytag ovens, it can be a problem with the oven temperature sensor.
If it is a keypad error, the test for which part has failed is straightforward, if they are sold as separate units. Unplug the oven and move it out to reach the back of the control panel. Unplug the ribbon connector for the touch pad from the clock. It's a flat wide (~1 1/2") wire. Make sure that the wire will not touch anything and cause a short. Plug the power cord for the range back in. If the F1 error recurs promptly, replace the ERC. If after 30+ minutes, the F1 error has not returned, replace the touchpad. If the touchpad and the ERC are sold as an assembly, you'll need to replace the entire unit.
For the oven temperature error, you'll need to check the continuity and resistance of the wiring across and around the sensor and back to the ERC. Check the wiring harness as well for any corrosion. Replace the sensor or the wiring depending on what you find.
I hope this helps. Please add a comment with the make and model of your oven for additional support and replacement part suggestions.
Jul 08, 2015 | Ovens
Stopped f1 flashing and beeping by adjusting the lock feature to 12 o clock not oven and self cleaning not working at all
You have disabled the oven feature if you did adjust the door lock assembly. Interesting that the F1 stopped. notsure why myself.\
Usually the F1 feature does not go away unless you replace the electronic/control board.
I wonder what would happen if you set the door lock assembly to where it was before?
Oct 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My oven..whirlpool model...has F1 in the display window. What does this mean?
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
Solve it with replace electronic oven control (also called EOC or clock).
Hope helps.
May 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I HAVE (FO) ERROR CODE ON MY KENMORE OVEN. IT WILL NOT WORK AT ATT
Hi. This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
NOTE_ If your unit is equipped with an integrated control assembly, simply replace the entire assembly.
Jan 05, 2010 | Ovens
The control panel went dark. Can only read it
Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Profile JTP56 Electric Double Oven
When the oven is turned on to preheat, the buzzer goes off and an "F1" error message is displayed and the oven turns off. The model # is MGR5750ADW. Is there something we can do to fix it?
An "F1" error code means you have a defective clock assembly (also called ERC- electronic range control). You will need to replace the clock assembly, and they are not cheap, around $200. Hope this helps you, good luck.
Oct 04, 2009 | Maytag Ovens
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
I have a kenmoore oven model 91140465690 that keeps beeping and flashing the code F7 i need to know what part i need to replace for that code
HI, this F-7 code represents one or more function keys on the control board that are malfunctioning or stuck.
This will require the replacement of the entire control board(ERC,Clock).
Replacing the ERC(Electronic Range Control), will fix this issue. this control board will run you about $140.00 tops. you can order it on line by clicking the link i have provided below this text if you choose.
Click here to order you new replacement ERC.
Jun 17, 2009 | Kenmore Ovens
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag 30" Built-In Double Electric Wall Oven - Black Logo
102 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
