Question about Samsung SyncMaster 931B 19" LCD Monitor
Syncmaster 931B samsung has blue light flashing slowly then fast on the second blink then slow again and the image wont show the desktop it self is working fine
  • Lou Ebert May 11, 2010
    beenwriting, Samsung KNOWS they have a problem! If your unit is less than 36 months old you still might be able to get a replacement FOC. try calling Samsung at 1 800 samsung. If possible find purchase recipt. If you can't get any help at samsung then get back to me at fixya and we will try to help you out. Your described symptom sounds like the 931B might have a power supply failure. louie12fix or lmistyrel @aol.com Even if Samsung replaces your monitor, please get back to us and tell us about how well they did about replacing it!!!! We want to know!!
tantong
  • 138 Answers
SOURCE: blinking blue light
You have to check if you can see the image on the screen or not after it went blank (Power on both CPU and monitor) by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you
Posted on Mar 13, 2008
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
  • 29 Answers
SOURCE: my samsung syncmaster 2232bw wont turn on at all,
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Posted on Jan 07, 2010
rj_8017
  • 22 Answers
SOURCE: samsung syncmaster 913v has no image power light flashing
replace capacitors 1000mf/25v 470mf/25v...
Posted on Jan 23, 2010
budmrtn
  • 11361 Answers
SOURCE: screen blinks on /off - can syncmaster 931b be
This model was released in 2001, you need to open it up and look for bad caps with bulging top first, the problem can also be in the backlight inverter circuits. Post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 28, 2010
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Screen blinks on /off - can syncmaster 931b be repaired?
Feb 27, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Black screen with power switch flashing blue.
I have been same problem but in other type syncMaster, the solution is open your LCD monitor look for power supply module (PCB which have connector to AC power), on that PCB look for capacitor , for normal condition its look like small tube. now look for broken one which upper part is bloated.
Nov 23, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Image flashes on and off on screen.
Try making sure the connections are tight on both ends
Apr 19, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Monitor is black and blue light flashing
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Mar 25, 2008 | Computers & Internet
Blinking blue light
Thank you
Mar 12, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 931B 19" LCD Monitor Logo
805 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
