Question about Bell Cocoon Child Carrier
My door bell stopped working, what could be the problem and how do I repair it?
  • 85 Answers
Most likely the transformer which can be found by your fuse pannel, replacement of that is cheap and easy. If you replace that and it still dosent work, you might have to replace the bell. One way to test if it is the bell is disconnect it from the wall and attach a battery using some scrap wire to it, and see if it works. If it does then its the transformer, if not then its the bell.
Posted on Oct 03, 2009
Why has my Honeywell DC313NHGBS plug-in wireless door bell unit suddenly stopped working. The battery unit is fine.
Door ringer is defective or the doorbell transmitter is not sending a signal or the bell is not receiving the signal due to a part failure.
Sep 28, 2016 | Honeywell Home Security
LE error code, bell ringing
Not an expert, but we paid $60 for the repair man to come out and just run his hand along the touch pad on the door. It stopped the error code and the bell ringing noise! I wish they would have mentioned that over the phone and I could have saved $60!
Nov 10, 2010 | LG LDF6810ST Stainless Steel Built-in...
My car door bell has fallen inside the hole that supports it and now my door bell wont stop ringing. What can I do to stop it from ringing?
If you're referring to the Courtesy door switch (interior light turns on when you open your door), then quickest solution would be to locate the interior light fuse (inside fusebox) and remove it (key off).
However, it is possible that other devices like Keyless entry, Radio etc, may also run off the same fuse. If this is the case, then the safest bet would be to have someone remove the inside door panel (the one which the switch has fallen through) and disconnect the courtesy switch connector, until you have had the switch repaired.
Cheers,
Nov 12, 2009 | 1998 Ford Mustang
Bell rings when I pull the key out and open the driver door
Replace the ignition switch or take to a dealer they may be able to repair the switch.
Oct 10, 2009 | 2006 Chevrolet Impala
The ignition bell wont stop ringing
You need to unplug the door harness one at a time to locate which door is causing the problem. Once the door is located, you can replace the switch which is located on the lock mechanism.
Sep 29, 2009 | 1994 Ford Ranger Supercab
Door bell stop working
hello sir/mam
the batteries in the door bell are discharged and you can replace the batteries these batteries will be available at electrical stores.
Sep 29, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Warning bell won't stop sounding
Sounds like your door sensors are going bad and are not relaying to the computer that the doors are fully closed, with that being said you will need to replace them and also at the same time it will stop the door locks from going crazy
May 16, 2009 | 2000 Ford Windstar
I have a 1996 Ford Mustang. When I insert the key into the ignition there is a bell sound. Usually this bell sounds stops as soon as the engine starts. But Lately, the bell sound will not stop. The bell...
Your door switch is out of adjustment or is just going bad. Even if your interior lights turn off when you shut the door, the switch is still out of adjustment or just going bad. take it to the dealer and have them look at it. they should be able to solve the problem for $20.00 or maybe even for free if you have them do other work like an oil change.
Apr 26, 2009 | 1996 Ford Mustang
Car door bell won't stop ringing.
is there any type of check engine light on or any type of warning light is the sound of the bell the same bell sound when you open your door or seatbelt warning
Aug 28, 2008 | 1997 Plymouth Neon
Bell Cocoon Child Carrier Logo
1,033 people viewed this question
Top Bell Sport & Outdoor - Others Experts
Are you a Bell Sport and Outdoor - Other Expert? Answer questions, earn points and help others
