Question about Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P
Need to change the blade on my sawsall - Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P
  • 8,404 Answers
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Posted on Sep 29, 2009
I have a 22hp Briggs from a JD L120 trying to replace the case gasket but the drive pulley is rusted on.
Try a 6'' or 8'' bearing puller. if not then a sawsall with a heavy duty metal cutting blade. 6''
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 30, 2017 | Briggs Garden
Why is my reciprocating carver leaking black goo?
Terri, this is grease leaking from seal on col-let shaft, or loose bolts/cracked casing. Take apart and repack gears and housing with lithium grease ( do not over pack) and change seal if possible.
My old sawzall from the 1980 has started to leak
sawsall leaking grease
http://www.shopfloortalk.com/forums/showthread.php?t=24494
Feb 24, 2016 | Saws
My Alternator is seized to it's bolt, how do i take it out, and where can i get a new belt?
Usein a sawsall and a .022 blade to take it off and any auto parts store will have a belt for a civic
May 17, 2011 | 1995 Honda Civic
I have lost the "ball"
I don't have one here, but you can download the owners manual/breakdown by going to "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to get the information. Let me know if you need more assistance.
Apr 22, 2011 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Cutting an opening in a steel door for a doggie door. Bought a Sawsall just for this. Any tips?
be sure to use eye protection and gloves to protect you from sharp edges.
first mark your lines on the door using a square, then drill holes large enough for the sawzall blade to fit through in all 4 corners. next use the sawzall to cut your straight lines which were alraedy marked and you now the opening you need. if necessary use a file or dremel tool to clean up and debur edges. hope this was helpful, if so please rate.
Feb 17, 2011 | Milwaukee Tool Milwaukee Super Sawzall...
My blade is in upside down. How do I get it out?
I don't know how much help I can be becauseI've always had millwaukee sawsall and on them the blades are reversible. Havve you tried loosening retaining screw up and using pliers right at base or foot and just grip it tightly and rock it up and down a little bit..while pulling stright out.Hope this helps. Good luck Thanks
Nov 14, 2010 | Craftsman 8 amp Reciprocating Saw with...
Plugged electric sawzhall in, no power. checked cable -- ok, checked both brushes, still have about 3/8in in each of them. What should I do next? Just replaced the blade, but I do not think that has...
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Jun 29, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
Jan 21, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P Logo
158 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
