Question about Xincom XC-DPG602 Router (XCDPG602)
I can't set up the prstige 334 router.
When i connect with router,my internet can't go online.but when i use with moden cabel i can go,why?pls,solve it out this problem.wht do i need to do.i took the step by step but i couldn't still now.
0 characters
1 Points
My router doesn't want to recoginze my modem. i know there is internet on my moden because i just connected the wire to my computer and online. once i take the wire and plug it into my router Belkin...
if you have a tester for the connection to your modem to pc..the tester that i mean used by detecting if your utp cable are working..
Sep 19, 2011 | Routers
Cannot connect to internet via router WRT 54GS
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
May 08, 2010 | Linksys Wireless-G WRT54G Router
The cable doesn't connect thru the router and it does without the router
It's hard to figure out what you mean with the lack of detail, but I'm assuming you mean, when you connect your computer to the modem, it connects to the internet, but when you use the router, the internet stops working.
Sounds like the router is either configured incorrectly or not at all. Try reading the owners manual on how to set it up:
Link to page containing user manual and quick start guides
Apr 03, 2010 | Zyxel Prestige 334 Router
Hoy can I connect the moden with the router?
you can plug the ethernet plug from the modem to the internet plug of the router.
Sep 20, 2009 | 3Com OfficeConnect Router
Cannot connect laptops to internet. Main computer allows access but wireless router is not letting us connect to internet. Our isp provider has checked our connection and all is ok.
Check with ur firewall settings i think u have installed antivirus and firewall is enabled hence pls check ur firewall settings and check the internet connection. Hope this will help u in solving the prob...
Jul 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wbr-2310 error 112
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Jun 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I am unable to get into my Prestige 334 configuration screen
Read this its the manual for your router.
May 29, 2009 | Zyxel Prestige 334 Router
The default user name is "admin" and the password is "password" for your router. now you should be able to access You can change the password from there.
Jan 25, 2009 | Zyxel Prestige 334 Router
No internet connection
tobe honest try to uninstall internet explorer 7
Dec 09, 2007 | Belkin Wireless Cable/DSL Gateway Router
Open Questions:
See all Xincom XC-DPG602 Router (XCDPG602) Questions
Xincom XC-DPG602 Router (XCDPG602) Logo
Top Xincom Routers Experts
 C. Dante
C. Dante
Are you a Xincom Router Expert? Answer questions, earn points and help others
