Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
I had a popcorn kernal stuck in the latch, which made the machine not start. I removed the kernal, however, the lights come on, the heat comes on, bot no water or the rest of the cycle begins...help..
  • 4 more comments
  • lance206 Sep 29, 2009
    I have tried that. It doesnt help. I have held down start/cancel and the heat dry buttons. I have unplugged the power for three minutes...
    I have taken the front covers off, looked through the latch mechanism but found no other issues.
    There is a little water left in the basin, so I checked to see if there was a clog, by blowing air into the discharge hose. Air bubbles came up in the machine...
    I have tried holding down the start/cancel. It doesnt help. I have held down start/cancel and the heat dry buttons. I have unplugged the power for three minutes...
    how do i enter the code and where can i get the code from? In the meantime, I have unplugged the machine and will leave it unplugged for an hour or two...
    This machine worked yesterday... it is only a year old. I would guess the board is not faulty, but I suppose it could be.
  • lance206 Sep 30, 2009
    so the unplugging thing did not work...
    so, are you gonna provide that for me?????
    President:
  • 1,653 Answers
This seems as though there may still be something stuck in the latch area and is preventing the interlock switch for fully engaging to allow the water to get in to the machine. You need to check around the latch area - use a torch to get a good look.
If you are convinced that there is nothing there and everything is OK then check to outlet hose to make sure that it is not blocked or obstructed in any way. Also check that the filters are not blocked. You can check the drain function by adding 2 to 3 litres of water to the machine and then switching to the drain function and seeing if the water drains out. If not then there may be an issue with the water pump.
If it is OK then you are most likely to find a problem with the controller board, a connector may have come loose, or the water inlet valve has become faulty. These latter issues normally produce an error code and beeping so this is unlikely.
If all the above fails then I would call a service engineer.
Posted on Sep 30, 2009
  • 11,896 Answers
The control board may be faulty or in error stage. Try to disconnect from power source for several hours, Try pressing power button while unplugged to get rid of any energy that may be left in the system
Then try plugging back in later on, and see if system resets. Otherwise you will need a code to enter the maintenance cycle for the machine
Posted on Sep 29, 2009
  • Nate Stansfield
    Nate Stansfield Sep 30, 2009
    copy and paste this link in your address bar to view your manual if you don't have one.
    http://www.fixya.com/support/p439997-fri...
  • Nate Stansfield
    Then either the board is bad, or you will need to get a service manual and enter the diagnostic mode with the code in manual to reset the machine manually. If resetting doesn't work, then you will need a new board.
  • 8,197 Answers
Press and hold cancle button to reset dishwasher.
Why won't the kettle heat up to pop
The heating element needs to be checked to see if it has power and if it has burned out. To do this, you need a meter that checks voltage and resistance. To test it, locate the connections to the heating element and with the machine unplugged test the heating coil with the meter set to measure resistance. It should not be infinite. IF it is then the coil is burned out.
Jun 14, 2014 | Cretors Goldrush Popcorn Maker
Drum turns and turns. only burns the kernals doesn't pop them
If the drum is turning, then it should work. Are you putting enough oil in the pot? Make sure you let it heat the oil for a little bit before adding the popcorn. If you dont have enough oil or heat it will not heat the kernals properly and burn them. You just need enough to cover the bottom of the pot an 1/8 inch so.
Sep 22, 2010 | Gold Medal Kitchen Appliances - Others
Kernels jump up and out of maker while maker is working. At least 50% of kernels are wasted. Thanks for your help.
This won't totally solve the problem, but do the following:
  1. turn on the machine and allow to run for about a minute to allow the machine to get hot.
  2. add 1/2 again as much kernals to the popper
  3. tilt the machine back slightly while popping begins
this should reduce your wasted kernals!
Mar 15, 2010 | Toastess Hot-Air Corn Popper Popcorn Maker
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
Hi We had a fall festival at our local school yesterday afternoon and some folks that were helping us out emptied the top of My Model CCP-509 into te trash to get rid of the stale popcorn. When they dumped...
I don't have a mechanical/electrical or other problem all I am trying to accomplish is finding a drawer that was accidently thrown out when some people assisting in cleaning up a school's fall festival dumped the left over popcorn into the trash bag and was not aware that the small drawer that catches left over unpopped kernals fell into the trash bag. The trash was picked up and now I am out a drawer that is needed to operate this machine in thecorrect manner. I just needed to know if you knew where I could find such a part. Thanks you
Oct 19, 2009 | Nostalgia Electrics Helman Group CCP-509...
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Apr 10, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Ccp-510 popcorn popper pops only small amount and quits
I had the same problem when I firs bought mine. I followed the instructions as to the proportion of corn to oil. Forget the book! I found that with this machine I had to use three times the oil that was caled for in the instructions to get all of the corn to pop. Better yet, we started purchasing the premade kits with the oil, popcorn and salt. Since changing to both of these systems we have enjoyed GREAT ppcorn!
Feb 01, 2009 | Nostalgia Electrics Helman Group CCP-510...
Not all kernals are popping
Heat the oil longer before you put the kernals in.
Dec 16, 2008 | Maximatic Elite 8oz. Deluxe Popcorn...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
35 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
