Question about Garden
It won't idle I can prime it and it will start but wont stay running it's a murray push throttle free design 4.0 sprint 22''
  • 472 Answers
NEEDS A CARB KIT AND FLUSHED OUT
Posted on Sep 30, 2009
2011 Triumph Sprint GT high idle
Hey Graham..
Have you had it tuned up lately...if you had the valves adjusted, the intake valves are too tight...if no one has been adjusting your valves.. you might have an air leak..??
Does the engine rpm's "kinda float" around for a few seconds..idling high then settle back to normal..? .. YES. then its a classic symptoms of too tight intake valves.
Jun 28, 2017 | 2012 Triumph Sprint GT
Runs and starts great but won't idle
Hi, Emmett and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Message Board Motorcycle USA
2 stroke dirt bike problem Won stay running Please help motorcycles
Honda 650 Won Idle
http://www.sportbikeworld.com/forums/179-atv-dirtbikes/30570-bike-runs-fine-wont-idle.html
Mar 21, 2016 | Motorcycles
Why are so many trouble diagnostic codes being thrown
sounds like you speed sensor and your throttle poistion sensor
Sep 02, 2014 | Cars & Trucks
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
My Murray 20" 3.5 hp classic throttle free design
it possible snap its main rod if it freely spins no compression buy new motor
Jun 08, 2011 | Briggs & Stratton Garden
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Imurray 22" psuh mower will not stay running
No problem. If you found this helpful - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | Oregon Scientific Gator Mulcher 3-N-1...
My mower surges. its a Murray, model number
first check to see if you have good clean gas in it. No water. if you have good clean gas. then I would recomend taking the gas tank off wich should have a plastic carburetor mounted to it. after that is removed and free of excess dirt. take the carb off there should be 5 phillips head screws. pull the carb off gently while observing just how it all goes back together. you may want to take pictures. you will find a fuel screen that you should take off and clean with carb spray. also there is a fuel pickup tube clean that also with carb spray. a couple words of caution if using compressed air Do not carried away with it. also same with the carb cleaner to much of it in rubber primers is not good.
Mar 10, 2009 | Garden
Garden Logo
328 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
