Question about HP DeskJet F4280 All In One Printer InkJet
I cannot get my printer to print - i have inserted new ink cartridges and still the E shows up - i am not sure what the problem is.
    Scholar:
  • 67 Answers
Remove all the cartridges from the printer and perfrom the below steps.
  1. Press the On button (I cannot get my printer to print - i have inserted - c01416329.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Wait 60 seconds.
  4. Plug the power cord into the back of the product.
  5. Press the On button (c01416329.gif ) to turn on the product.
After you perform the above steps, re-insert the cartridges one by one and check for any error after you insert any particular cartridge.
You would face issues with refilled cartridges, they may work well for some time but once issue starts it goes on....
Any clarifications please comment....
Posted on Sep 29, 2009
PRINTER IS SHOWING "INSERT PRINT CARTRIDGE" WHATto do
try opening the printer and making sure the cartridge didn't become loose and see if it still has ink, if not you need to buy a new cartridge, if it has ink and is fully in place remove it and make sure there is no dried or leaking ink blocking the opening and if so clean it off with a dry soft cloth
Feb 22, 2015 | Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    After inserting new cartridges jobs no longer print. If you go into maintenance mode on the printer it scrolls a message "align cartridges" across the display. If you press the Check mark button at that...
    Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
    It is possible to get a Dell Series 9 ink cartridge with a bad sensor. Take it back to the place of purchase for a replacement.
    Rick
    May 21, 2010 | Dell 926 All-In-One InkJet Printer
    Left ligh keep flashing. after installing new ink.
    • Make sure cartridge is placed in properly,
    • Re seat the cartridge and check.
    • It should work
    Please rate my response!!
    Jan 29, 2010 | HP DeskJet 940c InkJet Printer
    Print cartridges missing or not detected
    Are they new cartridges?
    If so, have you removed the clear plastic protection strips from the cartridge heads?
    Sep 15, 2009 | HP Photosmart C4280 Aio Printer
    I have put a new Cyan ink cartirdge in put it will not print
    Make sure the cartridge is full y inserted if not will not print and it will aslo not display.
    Aug 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Ink cartridge not printing
    Did you pull the plastic tape off of the cartridge?
    Feb 09, 2009 | HP Photosmart C3180 All-In-One InkJet...
    New Cartridge - Black showing no ink
    u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
    Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
    Incorrect ink level reading
    kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
    Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
    HP DeskJet F4280 All In One Printer InkJet Logo
    125 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
