Question about GE Telephone pr521w
My phone has stopped ringing(it is an answering machine/corded phone), and on the screen that displays the date is reads "NO DATA" during incoming calls. I can make outgoing calls; I just can't receive incoming calls. I don't know what is causing this, and the manual has no answers.
  • 15,935 Answers
This is a problem with the Caller ID processor.
Usually after a power surge this problem will happen.
Unfortunately there is no "fix".
Try another phone outlet to make sure the problem is not in the line.
Other than that - you have a failed phone.
Thanks for using FixYa!!
Posted on Sep 30, 2009
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
I NEED TO ANSWER THE NEC DTERN 8 WITHOUT HAVING TO HIT THE LINE BUTTON THAT IS RINGING
If your phone is set to ring then the Answer key should also flash during incoming call, you can use that. If its not set to ring there is a program to set Answer key to flash without the ring, but it's in system programming, likely a vendor thing.
Jun 11, 2014 | NEC Dterm DTP 16D-1 Corded Phone
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Mar 24, 2010 | GE 29870GE1 Corded Phone
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Incoming calls briefly ring once then automatically kick over to answering machine. I cannot get any incoming calls
Are you using norstar voicemail system?
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
Jun 26, 2009 | NorStar M7208 Corded Phone
Caller ID
It does have caller ID but it is in the form of a speaker phone style anouncement during the answering machine message playback or during the ringing of the phone.  There is not a screen that displays the caller ID info.
Dec 09, 2008 | AT&T 1818 Corded Phone
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Lands Phones Logo
35 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
