Question about GE Profile JGS968 Gas Kitchen Range
Oven is not working
My oven will not just stays on 100. Does this oven have a pilot light???
  • 1 more comment
  • NYCGIRL Dec 20, 2007
    Thanks VANMAN69!
  • ITALIA56US Dec 23, 2007
  • jlbaziuk Jan 21, 2008
    Has anybody found a solution.
    The Bake, Roast and Convection all stay at 100 degrees but the broil works.
  • 23 Answers
Check your oven ignitor very common prob.
Posted on Dec 19, 2007
Error Code E-08 on Samsung Gas Range. Oven will not heat but range top works.
Is there a gas pilot light that stays lit all the time or does it have an electric pilot light that glows red to start the oven.Either way if it's a gas pilot the thermocouple is bad, if electric the igniter is bad.
Jan 03, 2014 | Samsung Kitchen Ranges
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have a Garland stove series #G286, the oven won't stay lit.
    it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
    Aug 27, 2009 | Garland H286 Gas Kitchen Range
    My belling countrychef 100 G oven won't stay lit
    There is a good possibility you have a faulty component called a thermocouple, this is heated by the pilot light of your oven and is the most common cause of flame outage.
    I would recommend you get a 'Gas Safe' qualified engineer to check it. The thermocouple should be no more than £30.
    I hope this helps.
    Jul 08, 2009 | Kitchen Ranges
    Oven does not work.
    Just a guess. There may be something called a thermo-coupler which needs to feel the heat of the pilot light before it will allow the gas to turn on. If it's not working ... no gas.
    Jul 08, 2009 | Ovens
    Oven pilot light won't light
    Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
    Apr 21, 2008 | Kitchen Ranges
    Roper gas oven won't work
    replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
    Mar 02, 2008 | Ovens
    GE Profile JGS968 Gas Kitchen Range Logo
    156 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
