Question about Kohler K-10430-VS Fort½ Single Lever Handle Kitchen Faucet with Side S...
Kospak chung cheng pulldwon single lever handle problem. It has come off and it seems to be stripped. I screw it back on, but it is loose and it falls off after using.
The handle is very loose. How do I tighten it?
Pop off the cap on the handle. You will see a screw under the cap. Tighten it down. Sometimes the handle gets stripped, in that case, you will need to replace the handle.
Jan 10, 2016 | Moen Kitchen Faucets. Finley Single-Handle...
There are two shower handles, one to divert to the shower head and another to divert to the rain head. one of these handles has loosened and falls away from the neck.
Look for an Allen screw hole the Allen is loose or has stripped and needs to be changed out. Sometimes if they are over righted they strip on bottom, also make sure it hasn't backed out completely. Some older handled have a square piece that the handle goes over then the screw is tightened under a plastic cap tha has hot H or cold C on cover.
Aug 29, 2015 | Grohe Home
Loose handle falls off during shower...I tightened the little screw in handle...doesn't seem very solid?
Hi Kurt,
I am presuming you're referring to a lever-style handle as opposed to a standard knob style which is held down with a substantial screw. The lever-style is held in place with a small allen-key screw in a low visibility area on the lever.
If correct, the tip of the allen-key screw is usually ground to a point. This point is usually to rest within a receiving depression/grove or the like. Ensure that your lever is aligned to permit this match. If the screw is coming lose despite this, back out the allen-key screw fully, clean the threads in the lever with rubbing alcohol, then apply a very small dab of light/medium strength Locktite. Re-insert the screw into the lever, and reposition.
Good luck.
Mar 04, 2015 | Home
Handle dome keeps coming off
Sounds like the setscrew that holds it on has either worked lose and is missing or is striped and no longer tightens properly. Replace set screw if missing and or replace set screw if the set screw is striped. If the threads are stripped in the faucet body the faucet itself will need to be replaced. This usually does not fall under Moen's warranty guidlines.
Mar 29, 2014 | Moen 7594EC Arbor Single Handle/Hole...
My lever on my single handle kohler shower faucet is very, very loose. How do I tighten the lever. I don't see any screws or place for an allen wrench
There should be a screw hidden under a cap. depending on the model/style it may be as small around as a pencil diameter or as large as a half dollar (the larger is most common on acrylic handles) Just gently pry this off and you should find a phillips screw underneath.
Feb 04, 2011 | Home
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
The entire faucet is lifting off and spraying water at the joint when the lever is activated and water is being used,do I need to call a plumber to repair this. It seems that the faucet cannot be screwed...
No you do not need a plumber,
below under the sink, there are two valves, One for Hot ,One for Cold.
Turn them to the right.make sure they are turn all the way with a little pressure at the end. Now the kitchen has no water.
With a wrench ot pliers remove the water hoses, There may be a little water left in the hose so don't panic.
Now this may be a little harder.
Put yourself all the way under the sink,with you on your back.
Do you see the taps. There may be a fitting with screws. remove screws and fitting. You should be able to remove the whole Tap.
With you new tap... Follow their instruction.
When you are putting the hoses back on.. make sure they are slightly snug.
We don't want it to leak again.
Turn you water back on and slowly turn on your taps.
Aug 05, 2010 | Rohl A3608LMAPC Single Lever Country...
How to remove single lever handle does it require a spceial tool, because an allen wrech doesn't work
Most faucets have allen screws holding handle on or it may be recessed back in handle or if it is striped out may need to get a bolt extracter you can get them at hardware store pretty cheap.
Apr 25, 2010 | Price Pfister Single Lever Handle Faucet...
Loose lever
pop cap off and remove screw,pull handle,now lift up on cartridge ,then position handle assembly on,make sure you hook around groove and set down.tighten up if it's a newer model,it will be a hex screw , but similar process
Apr 25, 2010 | Moen & One Handle Tub & Shower Faucet
Kohler K-10430-VS  Fort½ Single Lever Handle Kitchen Faucet with Side S... Logo
429 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
