Question about HP J4680 Office Jet All-In-One Printer
Hp j4680 says "paper jam"
My hp j4680 says "paper jam" when I try to print an an attachment of a scanned doc that has been emailed to me. When I open the printer up I find there is no paper jam and it seems to be fine after I push the OK button. Printer works great with all doc types. I am wondering if it isn't an issue with Microsoft picture/fax view which is the default for this type of document, because this occurs when I am trying to print from that program. I can save doc to paint and print the first page but only the first page. Which is not good for multi-page documents. Any suggestions?
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Try this. Sometimes you get that message because a previous jam was never fully fixed.
Posted on Oct 26, 2009
HP J4680 says "printing" but won't print
just check it weather it is detecting your pc or laptop. if it is detecting check it is scanning working fine or not, if it is scanning fine you need to update firmware and check it. still getting same issue you need to replace the main pca board.
May 16, 2014 | HP J4680 Office Jet All-In-One Printer
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
How do I scan a picture from the HP J4680 to computer
This is the step on how to scan docs using HP J4680:
    1. Press the "Power" button on the HP J4680 and lift the top cover. Place the document to be scanned on the scanner glass. Be sure the document is face down and properly aligned with the top, left-hand corner of the glass.
    2. Use the arrow keys on the control panel of the HP J4680 to select the "Scan" feature. Press "OK" to continue. Then Press the right arrow to select the scan feature. Press the "Start" button to begin the scan.
Dec 13, 2010 | HP J4680 Office Jet All-In-One Printer
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
Hi, i have a HP officejet J4680 all-in-one. The
Clean every moving part with suitable substance. It will be better that you get a support.
Aug 12, 2009 | HP J4680 Office Jet All-In-One Printer
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
When I turn my printer on (HP J4680) it always tries to load a paper and immediately jams (even if I cycle power an unplug). I cannot use it anymore....
If you disconnect the printer from the computer and your printer stops trying to feed paper when you turn it back on, then this solution likely won't help you.
  1. Disconnect the printer from the computer.
  2. Disconnect the power supply.
  3. Turn the printer back on.
  4. If the printer tries to load paper and jams again, your printer is trying to recover from a paper jam, so try this video. I'm betting if you follow the instructions in this video, you'll resolve a jam in the printer and solve your problem.
Jun 20, 2009 | HP J4680 Office Jet All-In-One Printer
HP J4680 Office Jet All-In-One Printer Logo
143 people viewed this question
Seeker5211
Seeker5211
