Question about Sony Playstation 3 (PS3) Console
Ps3 when i turn it on has a yellow screen and wont load games
Recently, when i turn on my playstation 3, it starts with a yellow screen and i am unable to load any games or movies. i tried to switch everything back to default with no success.. any ideas as to what my problem may be?
Try this:
Turn the console to stand by, you can do this by pressing the power button for 10 seconds.
When it is on stand by (a solid red light shows) hold the power button for 3 beeps, remove your fingers on the third beep which should be a double beep.
This should take you to reset your console. You should see 6 options. Select option 2 then the system will go blank. Repeat the above but this time select option 3.
Your PS3 should work after. Good Luck!
Posted on Oct 31, 2009
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
Screen goes blank and standby light keeps flashing red
How to fix ps3 yellow light of death 3. tips first
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then there are 2 options left for you on how to fix your ps3 safe and fast!
Send your playstation 3 back to Sony
You might think that this is an great option, but take a look at some statistics. Most users had to wait at least 4-6 weeks before they had their Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done! Does this still sound as a good option?
Jul 27, 2010 | Sony PlayStation 3 40GB System
Start up fault for playstation 3
This is yellow light of death, your ps3 is broke call sony for info on repair
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Just recently my ps3 wont play any games or dvd. It loads up everything as normal but whem you put in disc it jusy goes to a blank screen until you remove the disc. yellow ang green light will flash while...
it sounds like your laser is gone you can replace it if you have any knolage of opening a ps3 there are loads of videos of how to do this on youtube i my self had the same problem its not that hard to fix
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 wont load games
The Hard Drive might be bad and need changes.
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read any game/dvd
How old is your PS3?
Not loading 1 particular disc or all disc?
Assuming you PS3 starts up into the console screen, and fairly used, it might be time to replace the lens.
May 28, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will play blu ray but not game
lols check ur wires bro. the basic yellow, white and red wires. make sure the yellow i belive is connect properly. if that doesnt work then go to system settings and check for a solution there
Apr 15, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Wont play games or movies
my playstation wont play ps3 games but it will play movies and ps2 games.if i put a ps3 game in it frezzes...
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
My ps3 wont load games or it freezes when it turns on
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Aug 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,860 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
